powermill 2018
powermill 2018
Hello, Please kindly find the attachment and how can i overcome this error?
Accepted solutions (3)
kamalrajcv
Hi @Anonymous
Would it be possible for you to supply the PowerMill project with the toolpaths you've generated so that I could assist you better?
Kamalraj C V
Technical Support Specialist
Thank you for your reply,kindly find the attachment.
Chetan.Bankar
Hi @sudalaishaanak,
Thanks for supplying the project.
For ViewMill Simulating the Turning toolpath turning axis must be aligned along the global Z axis. If it not, as in your case then we get this error.
I tried aligning your model, block such that turning toolpath axis is along the global Z axis then I was able to ViewMill Simulate the toolpath without any error as can be seen from the video,
I hope this helps,
Thanks and Regards,
Chetan Bankar
Global Product Support
Submitting & Viewing Support Requests | Web Support | Phone Support
Thank you for your reply.I have one more quiry,How can I rotate, Global Axis system?
Chetan.Bankar
Hi @Anonymous,
Glad to hear that the provided solution helped.
To align the Turning axis with Global (transform)  axis you will have to invalid the toolpaths,  rotate the model by going to Edit > Transform > Rotate. After this you will have to rotate the turn feature and then  re-calculate the block and the toolpaths.
I hope this helps.
Chetan Bankar
Thank you so much....
