Powermill 2018 Tool Database Update
Message 1 of 19
I just installed Powermill 2018 on one of the new Windows 10 systems, but it cannot access the tool database. I pointed to the correct location, but I get an error saying I need to run the "Update Tool Database Utility". There are instructions on how to do this, but I do not have the utility on my machine anywhere.
Replies (18)
Message 2 of 19
jitendra.chaudhari
Hi @Anonymous,
Thanks for contacting Autodesk Community..
I have faced the similar issue at my end while opening the tool database in Autodesk PowerMill 2018. Following Steps helped me to resolve the issue-
1. Close all active sessions of Autodesk PowerMill 2018.
2. Download and Install the version of the Microsoft VC C++ 2005 from the following link –
https://autodesk.box.com/s/alnhcyov5dvxm3s40yysqafqphm1xujt
3. Restart the system.
4. Now browse to
"C:\Program Files\Autodesk\PowerMill 2018\sys\tooldb"
There you will find an application called "ADODC.exe"
5.  Right Click on this and tell it to create a shortcut. Windows will typically tell you to place this on the desktop.
6.  Locate the shortcut on your desktop or where ever you placed it. Right click on the shortcut and select properties. In the target line you will see the path as-
"C:\Program Files\Autodesk\PowerMill 2018\sys\tooldb\ADODC.exe"
Modify this path to -
"C:\Program Files\Autodesk\PowerMill 2018\sys\tooldb\ADODC.exe" -Regserver
7. Once you have modified this select OK then run the short cut.
Now Open Autodesk PowerMill 2018 and retry accessing the tool database.
Hope this resolves the issue accessing tool database at your end.
If this procedure resolves your query then please click on 'Accept as solution' for this post.
Thank you for your time and co-operation.
Best regards,
Jitendra Chaudhari.
Message 3 of 19
I tried these steps.
These are the errors i get.
Message 4 of 19
jitendra.chaudhari
Hi @Anonymous,
Thanks for contacting Autodesk Community Forum..
It seems seem issue with administrator rights here. Can you retry with following steps-
1) Press the Windows key on the keyboard or click Start
2) Type cmd
3) Right click on "Command Prompt" and choose "Run as Administrator"
4) Type in command prompt as -   "cd C: \ Program Files \ Autodesk \ PowerMill 2018 \ sys \ tooldb" (without quotes) and press Enter
(( Here enter After ‘cd’ enter the path PowerMill database path)) ..
5) Type "ADODC.exe -Regserver" (without quotation marks) and press Enter
6) close the Prompt window
Now restart PowerMill and tool database would work correctly as expected..
Please verify and confirm.
Thank you for your time and co-operation,
Jitendra Chaudhari.
Message 5 of 19
I also got that error when trying to import a database.
The solution you gave did not work for me. when i try to run the "ADODC" file, i get this error.
Message 6 of 19
Yesterday i found a way around the problem but it is not perfect.
If you install PowerMILL 2017 and run the "Register Tool Database Server" file in the Autodesk PowerMILL 2017 folder you can then use the database in powermill 2018.
Autodesk must work on a fix for this problem.
Message 7 of 19
jitendra.chaudhari
Hi @Anonymous,
This is known behavior and this have been already escalated to PowerMill development thorough a change request and development team is working on this.
I have extracted VC++  20005 from PowerMill 2017 setup only and and this installer would be added into the upcoming customer release for Autodesk PowerMill 2018.
Best regards,
Jitendra Chaudhari.
Message 8 of 19
worked a treat... thank you
Message 9 of 19
Message 10 of 19
iamcdn79
Have you created a shortcut of the ADODC.exe in your desktop?
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 11 of 19
When I click on right mouse button There is no option for creating shortcut
Message 12 of 19
i also tried on windows 10 but could not able to it i waist my 4 hrs in this.
Message 13 of 19
karan30782
Thanks_ it worked .. as you said... very very thank you..
Message 14 of 19
link no longer working, can you re link please
Message 15 of 19
been at this for 3 hours now on win 10 and still no luck
Message 16 of 19
yeah been trying to get this to work for a few days now. im thinking im just gonna uninstall powermill and use something else, not worth it at this point for a program that doesnt work and that i cant get support for.
Message 17 of 19
rui_rita
hi @Anonymous
try installing powermill v2018.0.4 update, this will install vc++ 2005.
Os melhores cumprimentos | Best regards
Rui Rita
________________________________
NEWCAM, Lda.
Message 18 of 19
After modifying path it says"
Message 19 of 19
ChristopherMarion
@Anonymous
Try copying and pasting the following path to your target line.  The problem could be the -regserver at the end of the target.  Needs to be called out exactly.
Go to C:\Program Files\Autodesk\PowerMill 2018\sys\tooldb
Create a shortcut to the desktop for the ADODC.exe file
Change the target properties of the shortcut to:
"C:\Program Files\Autodesk\PowerMill 2018\sys\tooldb\ADODC.exe" -regserver
Then run that as administrator.
The tool database should now be registered.
Hope that helped!
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
