Postprocess MachineView
Hi I am in Germany
a Help Teatcher on a Metall school Education Center CNC
"We" own about 60Machines CNC all Homemade
In December19 we recived a Licence to Powermill
THE workstation i now recived has Powermill Ultimate2020 installed
The Software does start up and workes as far as i see
THERE is no Machine and Postprocessor at all as far as a pmoptz FILE search on the PC got nothing
Question on Youtube Related Searches Autodesk info Channel
DOES the PC need to be online to get a NC code out ? // the Place Machineside got no Internet connection ,offline
Is it only via a Acountmanager Possible to get a Postprocessor Machine View file Generated ?
I can get Internet on PC via a Phone HUB !
FOR Accesing a Example POST what do i need Licence Number or can Powermill Download a Example post
The Goal is to get a 5Axis RTCP Impellar G-code within 1years Time on the Machine (Linuxcnc)
i will provide the STL files of the AXIS separated
NEXT Q: Can only Autodesk Produce a Machine View Postprocessor or edit it?
I Know im not a Professionel asking Person but im Alone on this and need some Help
The Center Workes on a NonProfit Base,Nonpaid Personnel like me,just People how Care on Students out of Concept.
Hi
I did find the MTD Guide under the Help Button and im making Progress
Thank you
The PC does not need internet to post out NC code, or use an MTD file. Our network is 100% air-gapped and everything functions fine. As for the post processor files go, on Windows 10 with V2020, the generic ones that get installed with the "Manufacturing Post Processor Utility" are located in "C:\Users\Public\Documents\Autodesk\Manufacturing Post Processor Utility 2020\Generic". If you're running homemade machines, It would be questionable if any of those would work well for you. If you have a sample of the g-code the machines controller is expecting, I'm sure I, or someone else, would be willing to help.
Thank you very mutch
im on it the generic ones are great for a starting point i think it is mainly the kinetics
maybe i need to turn the Axes on mashineController to fit the PM and postprocessor needs
my mashine is set to have
HEAD XZ
Table YAC
this maybe not a standard
i will see the HERMLE C1200 this has a setup like this
is there a Hermle C1200 in the postprocessor and mashine tool libary from Autodesk
as of Corona i took the pc Home and i got no connection to the education centerLicence to get a downlod option
also i dont even Know how and where to ask for the Files
