EXPORT TOOL DATABASE IN CSV
Zibaldo
Zibaldo
I found from Knowledge Autodesk a way to export the tool database in a csv file
(https://knowledge.autodesk.com/support/powermill/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...).
It works well, however I was trying to make one that can export all the data about the tool (include tool holder dimension, shank length /diameter, etc.) but how do I find the equivalent code (like $ent...)?
Than I found how to import them back in Powermill from this forum:(https://manufacturing.autodesk.com/forums/forum.delcam.com/viewtopicca99.html?p=54657&_ga=2.25943284...)
But then I have the same problem on how to import them. Is there a pdf or something where I am supposed to find it? I did try also to record a macro and check after but didn't work..
Thank you
Luca
That's not exactly what you asked for, but I hope you can make it based on that.
Export:
FUNCTION Main() {
// Tool export example macro
// The $ToolProperties freely expandable with valid members, and special handling elements.
// The separator character '"' is beacuse it cannot be a valid PowerMill name, unlike the comma character.
// The Map record separator is '|', Map field separator is ':'.
// The 1st member always 'Type', 2nd member always 'Name', the other members can be in any order.
// In the example the 'ShankData' and 'HolderData' special elemets. - The valid member names 'ShankSetValues' and 'HolderSetValues'.
   STRING LIST ToolProperties={'Type','Name','Diameter','Length','TipRadius','Overhang','DrillAngle','ShankData','HolderData','HolderName'}
   STRING ExportFilename = ''
   $ExportFilename =  FILESELECT "Please select tool export file"
// Handling of a previously interrupted macro run
   DIALOGS MESSAGE OFF
   FILE CLOSE export
   DIALOGS MESSAGE ON
   FILE OPEN $ExportFilename FOR WRITE AS export
   STRING Header=''
   FOREACH S IN $ToolProperties {
      $Header=$Header+$S+'"'
// Write field names
   FILE WRITE $Header TO export
   FOREACH T IN folder('tool') {
      STRING ToolData=''
      FOREACH P IN $ToolProperties {
         IF member($T._keys,$P) {
            STRING Cmd='$'+'PropValue ='+'$'+'T.'+$P
            STRING PropValue=''
            DoCommand $Cmd
// The empty fields replace with ' '
            $PropValue=select($PropValue=='',' ',$PropValue)
            $ToolData=$ToolData+$PropValue+'"'
         } ELSE {
            SWITCH $P {
               CASE 'Name'
// Special case: the member($T._keys,'Name') return with false (PowerMill 2017)
                  $ToolData=$ToolData+$T.Name+'"'
                  BREAK
               CASE 'ShankData'
// Shank data
                  IF size($T.ShankSetValues) == 0 {
                     $ToolData=$ToolData+' "'
                  } ELSE {
                     STRING Shank=''
                     FOREACH MapData IN $T.ShankSetValues {
                        $Shank=$Shank+$MapData.LowerDiameter+':'+$MapData.UpperDiameter+':'+$MapData.Length+'|'
                     $ToolData=$ToolData+$Shank+'"'
                  BREAK
               CASE 'HolderData'
// Holder data
                  IF size($T.HolderSetValues) == 0 {
                  } ELSE {
                     STRING Holder=''
                     FOREACH MapData IN $T.HolderSetValues {
                        $Holder=$Holder+$MapData.LowerDiameter+':'+$MapData.UpperDiameter+':'+$MapData.Length+':'+$MapData.Ignore+'|'
                     $ToolData=$ToolData+$Holder+'"'
                  BREAK
               DEFAULT
// Missing members, misspelling field names
      FILE WRITE $ToolData TO export
   FILE CLOSE export
 Import:
FUNCTION Main() {
// Tool import example macro.
// Supported tool types: Ballnosed,Tip radiused and Drill. The dictionary expandable.
   DICTIONARY ToolTypes={'tip_radiused','TIPRADIUSED','ball_nosed','BALLNOSED','drill','DRILL'}
   STRING ImportFilename = ''
   $ImportFilename =  FILESELECT "Please select tool import file"
   IF NOT  file_exists( $ImportFilename) {
      RETURN
   DIALOGS MESSAGE OFF
   FILE CLOSE import
   DIALOGS MESSAGE ON
   FILE OPEN $ImportFilename FOR READ AS import
   STRING Header=''
   FILE READ $Header FROM import
   STRING LIST ToolProperties=tokens($Header,'"')
   IF (size(ToolProperties) < 2) OR (ucase($ToolProperties[0]) != 'TYPE') OR (ucase($ToolProperties[1]) != 'NAME') {
      FILE CLOSE import
      MESSAGE INFO 'Wrong file -missing header'
      RETURN
   STRING LIST ImportData={}
   FILE READ $ImportData FROM import
   FILE CLOSE import
   INT Count=1
   FOREACH $Record IN $ImportData {
      STRING LIST ToolData=tokens($Record,'"')
      IF size($ToolData) != $size(ToolProperties) {
         MESSAGE INFO 'Wrong record Nr.'+$Count+' -different size '+size($ToolData)+' != ' + $size(ToolProperties)
         RETURN
      STRING ToolType=remove_first($ToolData)
      IF member($ToolTypes,ToolType) {
         STRING ToolName=remove_first($ToolData)
         IF entity_exists('tool',$ToolName) {
            $ToolName=new_entity_name('tool',$ToolName)
         STRING Cmd='CREATE TOOL "'+$ToolName+'" $ToolTypes[$ToolType]'
         DoCommand $Cmd
         ENTITY T=entity('tool',$ToolName)
         INT Field=2
         FOREACH P IN $ToolData {
            STRING FieldName=$ToolProperties[$Field]
            IF member($T._keys,$FieldName) {
               STRING Cmd='$'+'T.'+$FieldName+'="'+$P+'"'
               DoCommand $Cmd
            } ELSE {
               SWITCH $FieldName {
                  CASE 'ShankData'
// Shank data
                     IF trim($P) != '' {
                        STRING LIST Maps=tokens($P,'|')
                        FOREACH item IN $Maps {
                           STRING LIST Values=tokens($item,':')
                           IF size($Values) != 3 {
                              MESSAGE INFO MESSAGE INFO 'Wrong Shank data in Nr.'+$Count+'record. '+ $size(Values)+' != 3'
                              RETURN
                           EDIT TOOL ; SHANK_COMPONENT ADD
                           REAL V=real($Values[0])
                           EDIT TOOL ; SHANK_COMPONENT LOWERDIA $V
                           $V=real($Values[1])
                           EDIT TOOL ; SHANK_COMPONENT UPPERDIA $V
                           $V=real($Values[2])
                           EDIT TOOL ; SHANK_COMPONENT LENGTH $V
                     BREAK
                  CASE 'HolderData'
// Holder data
                     IF trim($P) != '' {
                           IF size($Values) != 4 {
                              MESSAGE INFO MESSAGE INFO 'Wrong Holder data in Nr.'+$Count+'record. '+ $size(Values)+' != 4'
                              RETURN
                           EDIT TOOL ;  HOLDER_COMPONENT ADD
                           EDIT TOOL ;  HOLDER_COMPONENT LOWERDIA $V
                           $V=real($Values[1])
                           EDIT TOOL ;  HOLDER_COMPONENT UPPERDIA $V
                           $V=real($Values[2])
                           EDIT TOOL ;  HOLDER_COMPONENT LENGTH $V
                           IF $Values[3]==0 {
                              EDIT TOOL ; HOLDER_COMPONENT IGNORE NO
                           } ELSE {
                              EDIT TOOL ; HOLDER_COMPONENT IGNORE YES
                     BREAK
                  DEFAULT
            $Field=$Field+1
You can open the parameter by clicking on the help icon, in the upper right corner of Powermill.
Or you can navigate to and open {Powermill Install Folder}/lib/locale/C/PARREF/index.html
If you scroll down to the Tools tab you can see all the fields you can access. Just replace {tool} with $ent.
Another option: use to_xml() function.  Sorry my post always quits, I can't paste the macro code.
Zibaldo
Thank you for yours answers! it is really close but for some reason 2 things happens:
-1 for the majority of the tools imported it give an error message saying "Not supported tool type" and than each tools doesn't have any shank and tool holder, but only the cutting data.. any idea?
Thank you a lot
Sometimes, in my limited experience, I find you have to try entity() and extract() commands (or a combination) to retrieve certain parameters. Given that there are roughly 86 parameters, some being arrays of values, it would be hard to go over each one and how to export and retrieve them.
That being said, I'd like to take a step back and question why a cvs file? If the intent is to just have a reusable tool database, or multiple different tool databases, that you can import back into a new project, you can just save the tools out as a template object and import that template, whether it be manually or via a macro.
If you create your tool library, in a blank project, and go up to File->Save As->Template Objects you can then, when you need that tool list again, go to File->Import->Template Object and you'll have those tools.
Depending on your intentions, that might be a better way to go about what you want. If there are a certain few values you're interested in, post them hear and we can try to help.
Zibaldo
It doesn't must be a CSV file, I just don't know hml so I thought it was a good start. The template file seams the best way, Thank you!
