Postprocesador powermill 5 axes for mach3
Message 1 of 15
hello good day I need a Postprocesador powermill 5 axes for mach3 I have tried to do it but for me it is very difficult and I have failed.
If any of you can help me I appreciate it very much
greetings to all
Thank you
Replies (14)
Message 2 of 15
thaont.cnc
You need 5 axis Table Table or Head Table?
Message 3 of 15
Sudhira
Autodesk Support
Autodesk Support
greetings to all
Thank you
Hi @Anonymous,
As your concern regarding post-processor, it's a task of our dedicated post-processor team. I would like to suggest you contact your reseller or account manager (whomever sold you PowerMill) to seek assistance in modifying this post. Otherwise, you can generate a case to help you in this matter by following the mentioned link. These are the solution for your query and get the right solution in right time.
Create & Submit a Case
Sudhira Dora
Message 4 of 15
powercam.ir
Send me the full specifications of the machine to give you the appropriate post processor
Message 5 of 15
Thank you very much for your reply
X axis 600 mm
Y axis 300 mm
Z axis 130 mm
Axis 240 Degrees
B axis 360 Degrees
Mach3 control software
5 continuous axes
again I thank you very much for your valuable help
Message 6 of 15
thaont.cnc
You contact my email: [email protected]
Message 7 of 15
powercam.ir
Please specify the distance between the two centers of the Rotary axis, in accordance with the image shown.
Consider the center and surface of table B as zero, and get the position of the center of the RA era in the image.
Consider the center and surface of table B as zero, and position the center of the A Rotary period as shown.
Message 8 of 15
good day
attached image with the measures q asked me
Message 9 of 15
powercam.ir
ok. I sent the files to your email. Use the simplest piece to test the post. For example, a few holes on a polygon.
Message 10 of 15
Hi good day
the files have not arrived to my mail
[email protected]
thank you very much
Message 11 of 15
Please send me this post processor
my email - [email protected]
Thank you 😊
Message 12 of 15
Please send me
thank
Message 13 of 15
Please send me top this postprocessor, my mail Is [email protected]
Thank you!
Message 14 of 15
Meysam_Ghorbani
Message 15 of 15
RenatoHF
Observer
Observer
Can you send to my a powermill post processing from mach3 5 axis  trunnion layout? I'm from Brazil. Thanks
