Post Processor Script: Checking axis mode for all toolpaths
Jaanyaar
Jaanyaar
Hi!
There are built in parameters that check a toolpath axis mode:
1. Axis Mode
2. Toolpath Axis Mode
These are useful for one toolpath or move. I need a function or expression to check all toolpaths at the beginning of the post processing.
If all toolpaths are 3 axis then A.
If there is a non 3 axis toolpath then B.
Thanks in advance.
iamcdn79
If you write an if expression in the 'Toolpath Start' command like %p(Toolpath Axis Mode)% == "3AXIS" with your commands underneath it.
Then an else if expression like %p(Toolpath Axis Mode)% != "3AXIS" with your commands underneath that and end if to close it, wouldn't that work for all toolpaths?
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Jaanyaar
@iamcdn79
That expression is suitable for one toolpath. It doesn't check all toolpaths in a program. Your structure is correct but the expression is not. A tweak is needed.
Jaanyaar
By more examination, I've found that the following expression works for the 1st toolpath.
program.Toolpaths.Item(1).AxisMode=="1"
Where 1 = 3AXIS
2 = 5AXIS
and...
How can I check all toolpaths?
iamcdn79
I think the only to do what you want is to create a UDP https://forums.autodesk.com/t5/powermill-forum/get-toolpath-tool-parameters-in-ampu-script/m-p/97363...
Windows 11 Pro
Jaanyaar
Axis mode for every toolpath is stored in CLData. So it is enough to have a script or expression to check those stored values. No need to a UDP.  I guess it's simple but beyond my knowledge.
Sean571
Sean Wroblewski
Applications Engineer
