Get Toolpath/Tool parameters in AMPU script
cfastNJWK6
Advisor Advisor
cfastNJWK6
I am trying to get {powermill}.Tool.FeedSpeed.LeadInFactor into a script in the post-processor.  The post is for a Heidenhain control.  We are currently using "Q" variables to set the different feedrates.  This gives the machine operator a chance to change all cut, rapid, link, and plunge feedrates at the beginning of the program.  I am having difficulty setting the initial lead in and lead out feedrates.  I need to figure out how to pass the {powermill}.Tool.FeedSpeed.LeadInFactor parameter to a script in AMPU.
I have tried the following and have received errors every time:
var IN = program.ActiveToolpath.GetParameter("%p(FeedRate.LeadInFactor)%"));
var IN = program.ActiveTool.GetParameter("%p(FeedRate)%"));
How can I pass this PowerMill parameter to AMPU?
CAMXPRESS
According to the AMPPU Reference you cold only able to get the followings with GetParam("%p(ParamName)%"):
- Feed Rate Type - The Feed Rate Type (UNDEFINED / CUTTING / RAPID / PLUNGE / SKIM / RAMP LEADIN / LEADIN / LEADOUT).
- Plunge Rate, Skim Rate, Variable Feed Rate, Feed Rate
I think the LeadIn/OutFactor not stored in any CLDATA record.
Another possible way to push this (or any) info to AMPPU from PM is to define a user parameter at PM, store the desired value in it (even with a macro) and after you able to get this value with a script at AMPPU.
Hope it helps to solve your needs.
Joe
cfastNJWK6
Thanks for the reply.
I was hoping I would be able to solve this issue without creating a UDP.  But at least now I know that if I want to preset the Q variables for lead in/out and link feedrate, I will have to create a UDP.
Thanks again.
