Post Processor Modification
newgentooling
newgentooling
Dear Sir,
               1)  We are Using Vary Toolpath in Same Tool. Initially First Toolpath Next Tool Command  Generate, Further Toolpath Next Tool Command  Generate But Same Tool Happen. We Need Next Tool Number.(Highlighted Red Color)
              2) In a Model We Generate 3D&2D Program. First 3D programming Toolpath Used Stock XYZ Consider.
Further 2D Programming Toolpath Used 3D programming Stock XYZ Automatic Consider. In Output Nc programming
Stock in XYZ Not Required 2D Toolpath.(Highlighted Green Color)
karan30782
could you simplifiy your question in detail .
what you want ?
and how ?
Clear your question in detail.
Thank you !
newgentooling
Dear Sir,
               As For Attached Image And Video Not Required Stock In XYZ Option Of 2d Nc Program Output Only.
cam.tech
Your modification request seems to be not understandable. Kindly explain what you want to modify
We provide post processors support for PowerMill, FeatureCAM and Fusion 360. Reach out to us via techcamindia@gmail.com for trail post processor.
newgentooling
Dear Sir,
                  Please Provide The Post Processer To Us newgentooling@gmail.com
