Create Folder In NC Program
newgentooling
newgentooling
Dear Sir,
                We Create The Folder Before Starting The Nc Programming. After Complete The Programming. We Required The Output With Folder.(Refer The Attached Video)
karan30782
Hi ! @newgentooling
You can try this if it can help you ....
STRING $dir1 = 'ABCV-01'
STRING $dir2 = 'AXCN-02'
STRING $dir3 = 'BGHP-03'
STRING $dir4 = 'BLPR-04'
STRING $dirpath = project_pathname(0) + "\ncprograms\" + '$dir1'
MKDIR $dirpath
STRING $dirpath1 = project_pathname(0) + "\ncprograms\" + '$dir2'
MKDIR $dirpath1
STRING $dirpath2 = project_pathname(0) + "\ncprograms\" + '$dir3'
MKDIR $dirpath2
STRING $dirpath3 = project_pathname(0) + "\ncprograms\" + '$dir4'
MKDIR $dirpath3
OLE FILEACTION "OPEN" $dirpath
Cheers ,
Pijetro
I stumbled upon this by accident.
But if you use a forward slash (/) in your output name, you will create a subfolder within the NC program..
I hope this helps..
newgentooling
Dear Sir,
                   Thanks For Your Support. Please ref Attached Sheet, We Required Automatic Folder NC output Program.
karan30782
Hi !
Otherwise you can use it this way also
//macro will create required number of folders with required name.
INT $nFolder = INPUT "Enter the number of folders"
INT $count = 0
//This will create folder in your toolpath explorer
WHILE $count < $nFolder {
STRING $folder = INPUT "Enter the folder name"
STRING $path = 'NCProgram\' + $folder
IF NOT folder_exists($path) {
CREATE FOLDER "NCProgram" $folder
//This will create folder in your ncprograms explorer
$path = 'Toolpath\' + $folder
CREATE FOLDER "Toolpath" $folder
$count = $count + 1
//This will create folder in your project directory ncprogram folder
STRING $dirpath = project_pathname(0) + "/ncprograms/" + '$folder'
MKDIR $dirpath
