post processor error broken connection
ahorwood
Message 1 of 11
ahorwood
i'm suddenly getting an error posting code. error cr0002 unexpected error location object: cldatareader. any ideas what's going on?
Aaron Horwood
Tonnard MFG
Replies (10)
Message 2 of 11
jonathan.artiss
Hi @ahorwood
Thanks for posting on the Autodesk PowerMill forum!
Aaron Horwood
Tonnard MFG
Was this working correctly before? Windows update?
What version of PowerMill and Post Processor are you using? What type of Post are you using? OPT, PMOPTZ?
Cheers,
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 3 of 11
ahorwood
worked Monday. did recently do windows update. version is 2018 on both.
Message 4 of 11
jonathan.artiss
@ahorwood
Go to the ? top right > About > Version number?
What type of post is it? OPT or PMOPTZ?
Cheers,
Jonathan Artiss
Message 5 of 11
ahorwood
Autodesk PowerMill Standard 2018 Version: 2018.1.4.1212164 Build Date: Sun Dec 03 11:17:44 UTC 2017 Status: Full Release
.pmoptz
Message 6 of 11
ahorwood
I've tried multiple .pmotz file, including the generics. also tried using 2017 PM with 2017 post processor. tied opening old file that i knew worked. and creating new files also.
Message 7 of 11
jonathan.artiss
@ahorwood
Is your NC program settings page set up correctly?
It might be best to upload your project and post to a support case.
Cheers,
Jonathan Artiss
Message 8 of 11
ahorwood
I started a support case. wish I had a quick answer so I can get back running again.
Message 9 of 11
jonathan.artiss
@ahorwood
Whats the support case number?
Anyone on an active subscription can call 866-681-4359
Cheers,
Jonathan Artiss
Message 10 of 11
ahorwood
case number 13700575
Message 11 of 11
ahorwood
problem solved. was a stuck windows update screwing stuff up.
