PM Robot for Kuka Extra External Declaration
Message 1 of 14
When I add a User Command in the NC program panel in the Vertical Plugin window for the robot plugin, the post processor correctly adds the command to the main .src file, but incorrectly adds an external declaration for that command to the main .data file.
Can someone help me correct this?
I've attached a zipped project archive for this PM project.
Replies (13)
Message 2 of 14
RAL6000
This can be corrected in the Post Processor.
Please Upload your Robotic Cell, then i will have a look where you need to change it.
kind regards Stefan,
Milling robot integrator | Germany
Message 3 of 14
I'm not sure how to upload the cell. Is it not in the project archive?
Message 4 of 14
RAL6000
No, the simulation cell and the postprocessor are not part of an PowerMill project.
To find out where it is saved, go into your Robot Plugin, Robot Database (where you activate the robot), in the upper area - click the button open robot database (1) and choose user defined (2) in the text document you will see all your user defined robots, their name and path on your hard drive.
Zip That archive and upload.
Message 5 of 14
Alright, I've attached a zipped cell with the model, the mtd and robconfig files, and the posts that I use. Let me know if you need anything else from me.
Thank you for your help with this.
Message 6 of 14
RAL6000
Your robot is not the one which is linked at the PM project.
The linked robot is called "\Kuka KR60_BW\KR60 + RotaryTable + HotwireLarge.mtd". You have send an Kuka Kr210... with a spindle. So i´m unable to make function tests.
Anyway, i expect the PriPost might be the same.
The used variable "!Programs.NoDuplicates[" + $Count + "].FileName!" in PriPost Line 368 is empty during your "COMMAND" postprocessing in NC program. When the variable is empty you will get the "EX ()" result in .dat File.
So what i would do is:
  1. Try finding an Alternative Variable (Page 20 in PM Post documentation)
    1. Documentation Source: C:\Program Files\Autodesk\Autodesk PowerMill Robot Plugin 2020\Help\PowerMill Robot - PostProcessors.pdf
  2. implement an If Case into the while loop which is avoiding creating the "EX ()" when the variable is empty
    1.   IF NOT !Programs.NoDuplicates[" + $Count + "].FileName! == "" {
      	  // Print the line
      	  PRINT $Line
  3. Contact Autodesk Support / create a ticket, the PriPost template Kuka.KRL.PriPost in PM2020 is the same at that point and i expect it will have the same problem
Message 7 of 14
Stefan, thank you for that.
I've added your code to the post:
WHILE Count < !Programs.NoDuplicates.Count! {
  // Check to see if !Programs.NoDuplicates.FileName! is empty
  If NOT !Programs.NoDuplicates[" + $Count + "].FileName! == "" {
	// Build the line to print
	STRING Line = "  EXT !Programs.NoDuplicates[" + $Count + "].FileName!()"
	// Print the line
	PRINT $Line
  // Increment the 'Count'
  $Count = Count + 1
However, I get the following error when it tries to evaluate the expression:
Would you please advise how to fix this code?
I've tried writing this If statement in several different ways and I keep getting the same error.
Thank you.
Message 8 of 14
RAL6000
well, you are right. That does not work.
Try following, where i use a temporary variable which will be filled with the "!Programs.NoDuplicates[" + $Count + "].FileName!" value.
  STRING temp_name = ""
 $temp_name = "!Programs.NoDuplicates[" + $Count + "].FileName!"
  If $temp_name != "" {
	// Print the line
	PRINT $Line
  $Count = Count + 1
Message 9 of 14
That code change now evaluates correctly, but still does not yet execute correctly - it still produces the incorrect EXT () declaration in the main .dat file.
I've uploaded the correct robot cell files so that you can load the project I uploaded. I've also sent a request to customer support for help in this as you requested.
Thanks.
Message 10 of 14
RAL6000
I changed your PriPost a little. Now it does not give an "EX ()".
In General i also did not found a solution to get the IF-CASE situation in a correct way.
No matter if i analyse the length of the string or its exact content. It everytime goes into the IF.
So what it have done is to use other functions to create the Main .dat file as you want.
Please make a full comparision and check your program files between new and old postprocessed files.
I got different TOOL_DATA results by postprocessing your .RobSim. Make sure you got the right ones.
Code snippets:
        <ProgramStart Enabled="True" >
          <![CDATA[&ACCESS RVO
DEFDAT !MainProgram.Name!
;FOLD EXTERNAL DECLARATIONS;%{PE}%MKUKATPBASIS,%CEXT,%VCOMMON,%P
  ;FOLD BASISTECH EXT;%{PE}%MKUKATPBASIS,%CEXT,%VEXT,%P
    EXT  BAS (BAS_COMMAND  :IN,REAL  :IN )
  ;ENDFOLD (BASISTECH EXT)]]>
        </ProgramStart>
        <NCEntityCall Enabled="True">
          <![CDATA[  EXT !Program.Name!()]]>
        </NCEntityCall>
        <ProgramEnd Enabled="True">
          <![CDATA[;ENDFOLD (EXTERNAL DECLERATIONS)
ENDDAT]]>
Message 11 of 14
Stefan, that works!
Thank you very much for your help.
Message 12 of 14
Stefan, I'm still having problems with this post. Are you still available to help with this, or should I post a new help request?
Message 13 of 14
RAL6000
what kind of issues do you have?
Message 14 of 14
Good afternoon, please help me find a postprocessor for the robot KUKA 210.  format  postprocessor  pmoptz
