Paste Clipboard Contents into STRING
TK.421
Advisor Advisor
TK.421
Is it possible to paste whatever text I've copied from somewhere else into a string? Something along the lines of:
STRING paste = CLIPBOARD PASTE
message info $paste
thanks in advance
david
the numbers never lie
GetClip.mac:
FUNCTION MAIN() {
   STRING bat= macro_path(0)+"\getClip.bat"
   STRING file1= macro_path(0)+"\getClip.txt"
   STRING file2= macro_path(0)+"\getClip.OK"
   IF file_exists($file1) {
      DELETE FILE $file1
   IF file_exists($file2) {
      DELETE FILE $file2
   STRING cmd='powershell -command "Get-Clipboard" >"'+$file1+'"' +crlf+'ECHO OK >"'+$file2+'"'
   FILE OPEN $bat FOR WRITE AS "output"
   FILE WRITE $cmd TO "output"
   FILE CLOSE "output"
   OLE FILEACTION "OPEN" $bat
   WHILE NOT file_exists($file2) {
      INT I=0
   STRING Clipboard=""
   FILE OPEN $file1 FOR READ AS "file1"
   FILE READ $Clipboard FROM "file1"
   FILE CLOSE "file1"
   DELETE FILE $file1
   DELETE FILE $file2
   print=$Clipboard
ToClip.mac: - for entity context menu - such as model
FUNCTION MAIN(STRING S ) {
STRING P= macro_path(0)+"\ToClip.bat"
STRING CLIP="ECHO | SET /P=" +$S+" | CLIP"
 FILE OPEN $P FOR WRITE AS "output"
      FILE WRITE $Clip TO "output"
      FILE CLOSE "output"
 OLE FILEACTION "OPEN" $P
TK.421
that is wonderful, thank you so much!  it took me an hour to figure out i had to update powershell. works like a charm
david
TK.421
the finished product is attached of what I wanted to use the clipboard for. I,J,K values copied from another program
thanks again
