We are currently experiencing an issue impacting some Autodesk Products and Services - please refer to the Autodesk Health Dashboard for updates.
Notepad++ Language for editing PowerMill macros.
Message 1 of 30
If you would like to edit your PowerMill macro in full colours, you can use Notepad++ editor with a user defined language.
You can also fold code, because {} characters are set as keywords for folding.
I have attached a .zip file that contains the PowerMill language, and a macro example.
You can download Notepad++ text editor from here: https://notepad-plus-plus.org/download
In Notepad++ click "View > User Defined Dialogue..."
Click Import button and select the "Notepad++PowerMillLanguage.XML" file.
Open a the PowerMill macro example "CreateBlockAndWorkplane.mac".
Code should now appear colour coded. You can fold code by "View > Fold All" command, or by clicking + and - markers.
You can comment and uncomment selected lines of code using Ctrl+Q shorcut.
If you can't see the marco in colours, try "Language > PowerMill" command from the top menu.
Screencast for using the PowerMill language in Notepad++ can be found here:
https://knowledge.autodesk.com/community/screencast/e7d3e8e1-5222-431d-abc0-caa356d6342
Replies (29)
Message 21 of 30
iamcdn79
Take the mac.rar, uncompress it then move the mac folder to C:\Users\your user name\.vscode\extensions
Credit to @TK.421 for this extension
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 22 of 30
t_dueber
i have the same issue
Message 23 of 30
t_dueber
figured it out.
I changed the hex colour code from "000000" to "00ff00" in the previous uploaded file as you can see in the screenshot.
Also set the marker as in the Pink bubble. Then you will have this look which looks okay to me.
Message 24 of 30
nguyenthinhvt95
Thank you very much, now it 's working well.
Message 25 of 30
arnoldiW3K8A
Hello, today after many test i find a solution to add the add the autocomplation in notepad ++ 8.6.
i paste in  "C:\Program Files (x86)\Notepad++\autoCompletion\" the file xml in attached
Message 26 of 30
moraschini
Hello Everyone, i hope to be usefull for someone of you,
today after many test i find a solution to add the hint and the autocompletion in notepad++ 8.6.
you have to copy the file in attach in "C:\Program Files (x86)\Notepad++\autoCompletion\"
with this passage i get this result.
have a good day
Message 27 of 30
nguyenthinhvt95
After pass the file in C disk, how to setting in Notepad++ to use this?
Message 28 of 30
arnoldiW3K8A
hello, you need the powermill language that you load from
language>User Defined Language>Define Your Language...> import...
here you have to choice the powermill language, in attached the one created by me
close notepad++ and reopen, open a file with extension '.mac' and start writing.
if everithing works fine when u start writing it should show the hint and on the function (maybe with ctrl+space key) the terms of the function.
Message 29 of 30
nguyenthinhvt95
Now It's working well.
Thank you very much
Message 30 of 30
moraschini
hello, happy to  helped you
