Announcements
No feed rate shows in Heidenhain post file
karan30782
karan30782
Hi !!
All,
I was trying to modify option file for Heidenhain controller. And while editing the post I don't know how, but now when I post any nc program with this post processor all feed parameters convert to +1.
Someone please help me out.
Earlier all was fine, but just after modification all feed gone.
I have attached the option files, nc files and the reference images.
Thanks in Advance !!!
This is Right oneThis is Right oneThis is WrongThis is Wrong
ChristopherMarion
Hi @karan30782
I took a quick look and I don't see anything wrong.  If I post with either of the supplied posts, I get the same feeds.
The main difference is the space between the line number and Q variable....which is what you added.
Perhaps there is something else going on.  I'd try closing everything down and try again.
Christopher Marion
Technical Specialist - CAM
SolidCAD - Canada
cfastNJWK6
I posted one of my programs with your modified post and it came out as expected.  Are you sure you have the feedrates set correctly in PowerMill?  I see that you are comparing two different programs.
karan30782
Hey @ChristopherMarion and @cfastNJWK6
Yes, that was my mistake.. I copied the post processor to another PC & the result was as expected.
Thanks to both of you !!!
