Need macro help to save template to a folder
johnc4668
johnc4668
Is there a way to setup a macro to save templates to a certain folder? Right now powermill just brings up the standard powermill window folder but we dont save them there. I need to save it to Z:\Software\PowerMill\Powermill_Templates and have the folder open to this destination. Not a big deal, but this would save our operators some time.
iamcdn79
Try adding this to your macro
STRING $Filesave = ""
$Filesave = FILESELECT "file location here"
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
rafael.sansao
$Filesave = FILESELECT "Select template" "*.ptf" "Z:\PATH" //change this path
KEEP ADVTOOLPATH ; $Filesave
Rafael Sansão
OptiNC - www.optinc.tech
johnc4668
@rafael.sansao, worked great thanks! this could work for a template open macro too right? Maybe just change the $filesave to $fileopen? Pm doesnt have an option to open templates from a certain path everytime i believe.
rafael.sansao
The path string that the "FILESELECT" returns, can be used for anything.
To import a template, use:
$Filesave = FILESELECT "Select template to open" "*.ptf" "Z:\PATH" //change this
IMPORT TEMPLATE PROJECT $Filesave
Rafael Sansão
johnc4668
Worked great, thanks!
johnc4668
@rafael.sansao Tested this macro again and it seems to only save the active toolpath rather than all the toolpaths, workplanes, boundaries, tools, etc. I need this to save everything in the project if possible.
