Need Help With Macro to add notes to nc program set up sheet
josh.cowley.ctd
josh.cowley.ctd
Can anyone help and explain to me what I'm doing wrong here? I am defiantly a macro noob and really want to get better at them.
I am working on a macro to write my datum locations to the nc program notes so I don't have to retype it every job for the guys in the shop to get more clarification of location
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
//CREATES SELECTABLE OPTIONS IN A USER INPUT WINDOW
STRING ARRAY A[] = {"Top","Centered","Bottom"}
//NAME OF USER INPUT WINDOW
INT Z = INPUT CHOICE $A "Select Z Location?"
//CHOOSES Z OPTION 1
if $z == 0 {
TOP
//CHOOSES Z OPTION 2
} elseif $z == 1 {
CENTER
//CHOOSES Z OPTION 3
} elseif $z == 2 {
BOTTOM
EDIT NCPROGRAM $active_NCPROGRAM NOTES "Z"    HOW DO I GET THIS LINE TO WRITE THE CHOSEN TEXT FROM $z VARIABLE
DIALOGS MESSAGE ON
DIALOGS ERROR ON
If anyone would lend their expertise I would be grateful
Thank You
Sean571
// Create Build the Note as a string
STRING ncNotes = "Z " + $A[$Z]
// Set the notes equal to the $ncNotes variable
EDIT NCPROGRAM ; NOTES $ncNotes
Sean Wroblewski
Applications Engineer
josh.cowley.ctd
Thank you very much for your assistance!!! I greatly appreciate it!
josh.cowley.ctd
For anyone interested, here is the final result. This will add your datum location to the ncprogram user defined notes, which will show in your set up sheets
Thanks again Sean for your help!
//Adds notes to "NCPROGRAMS USER DEFINED NOTES"
EDIT PAGE NCPROGRAMNOTES1
QUIT FORM NCPROGRAMNOTES
//CREATES X
STRING ARRAY A[] = {"Left","Center","Right"}
INT X = INPUT CHOICE $A "Select X Location?"
STRING ncNote1 = "X " + $A[$X]
//CREATES Y
STRING ARRAY B[] = {"Front","Center","Back"}
INT Y = INPUT CHOICE $B "Select Y Location?"
STRING ncNote2 = "Y " + $B[$Y]
//CREATES Z
STRING ARRAY C[] = {"Top","Centered","Bottom"}
INT Z = INPUT CHOICE $C "Select Z Location?"
STRING ncNote3 = "Z " + $C[$Z]
// ADDS MULTIPLE VARIBLES TOGETHER FOR FINAL STRING
STRING ncNotes = $ncNote1+","+" "+ncNote2+","+" "+ncNote3
nubrandao
Can you show a imagem hás exemplo?
ramaprasad_narayan
Hi
Could you please share a report how it is working
