Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
NEED HELP! Fixture offset for all toolpaths within nc program
johnc4668
johnc4668
Macro noob here! I am trying to create a macro that creates an nc program for all toolpaths within the project and use a fixture offset to sink them in the z axis. I am having trouble finding a command to select all toolpaths in the nc program window. Any help would be great!
Heres my macro so far....
CREATE NCPROGRAM ; EDIT NCPROGRAM ; QUIT FORM NCTOOLPATH
RENAME NCPROGRAM "1" "SINK_TRODE-.025"
NCTOOLPATH ACCEPT FORM ACCEPT NCTOOLPATHLIST FORM ACCEPT NCTOOLLIST
EDIT NCPROGRAM ; APPEND TOOLPATH ALL
EDIT NCPROGRAM "SINK_TRODE-.025" QUIT FORM NCTOOLPATH
EDIT NCPROGRAM 'SINK_TRODE-.025' SELECT\r 1 SERIES      <<<<<< NEED A DIFFERENT COMMAND HERE TO SELECT ALL TOOLPATHS IN NCPRG
EDIT NCPROGRAM 'SINK_TRODE-.025' ITEM SELECTED COMPONENT SELECTED FIXTUREOFFSET "2"
ACTIVATE NCPROGRAM "SINK_TRODE-.025" KEEP NCPROGRAM ; YES
NCTOOLPATH CANCEL FORM ACCEPT NCTOOLPATHLIST FORM ACCEPT NCTOOLLIST
TK.421
this will pull all the names from the nc program that is active:
STRING ncProg = entity('ncprogram','').name
STRING LIST ncP_toolpaths = extract(entity('ncprogram', ncProg).nctoolpath, 'Name')
FOREACH tp IN ncP_toolpaths {
put your commands here
for more clarification, you can read this thread
the numbers never lie
johnc4668
TK.421
Thanks for your help, Im almost there but its still not doing what i want to do yet. It is still only selecting 1 toolpath in the nc program window and not all of them. Heres my updated macro
TK.421
try this:
CREATE NCPROGRAM "SINK_TRODE-.025"
INT item_num = 0
INT comp_num = 0
     IF !is_empty(components(entity('ncprogram',''))) {
          IF components(entity('ncprogram',''))[0].RootType == 'nctoolpath' {
               EDIT NCPROGRAM ; ITEM $item_num COMPONENT $comp_num FIXTUREOFFSET "1"
     $item_num = $item_num + 1
     $comp_num = $comp_num + 1000
ACTIVATE NCPROGRAM $ncProg KEEP NCPROGRAM ; YES
changing settings for toolpaths in an nc program is kind of goofy. try the above and see how that works - i think it should.  I also cleaned up some stuff that you dont need
johnc4668
worked beautifully! cheers!
