nc program output folder macro variable
Message 1 of 8
Does anyone know the variable that would call out the current output folder under NC preferences?
Replies (7)
Message 2 of 8
rafael.sansao
STRING $nc_output = $widget('NCPreferences.Shell.MachinePref.Frame1.Folder').value
PRINT $nc_output
Rafael Sansão
OptiNC - www.optinc.tech
Message 3 of 8
I'm trying to do this..
STRING $nc_output =
$widget('NCPreferences.Shell.MachinePref.Frame1.Folder').value PRINT
$nc_output
SETUPSHEETS FILE "$nc_output/{project}/{project}.html"
where my setup sheets would actually be created in the same directory
wheregrams to.
Message 4 of 8
rafael.sansao
STRING $nc_output = $widget('NCPreferences.Shell.MachinePref.Frame1.Folder').value + '/{project}/{project}.html'
SETUPSHEETS FILE $nc_output
Rafael Sansão
Message 5 of 8
Perfect again. Thank you again sir.
Message 6 of 8
When I try to insert this line at the beginning to reset the file and delete the existing folder it does not work.
STRING $Reset = $widget('NCPreferences.Shell.MachinePref.Frame1.Folder').value + '/{project}'
DELETE DIRECTORY $Reset
Am i missing something?
Message 7 of 8
rafael.sansao
If you use the dedduger macro, it's easy to verify that the variable path is correct:
STRING $Reset = $widget('NCPreferences.Shell.MachinePref.Frame1.Folder').value + '/' + project_pathname(1)
Rafael Sansão
Message 8 of 8
thank you...hopefully last time that I bother you, much appreciated.
