Multiple Post Processor Questions (Drilling, Max Feed, Max Note length)
matthew_metzingerRD8F6
Good morning.
I'm in PM 2024, and have a few questions about modifying my post processor, for a Haas.
When I do drilling, I am getting hundreds of lines of code, for the drilling, that would normally say be G83.
When I use say Break Chip cycle type, with Drilling Cycle output checked ON in the operation, and go and post it, also with Drilling Cycle Output checked ON in the NC Program posting dialogue, I get lines and lines and lines of code for the drilling moves.
Is there something in the Post that I can set to get Drilling Cycle output?
Is there a way in the post processor to limit the maximum output feedrate?
The Haas I have maxes out at I believe 400ipm, and I keep missing feedrates from older files, that have 750ipm feeds.  I'm constantly having to go back, fix feeds, repost, etc. etc. etc...
Is there a way in the post processor to "break" comment lines, that are too long, into multiple lines of comments?
The Haas I have is erroring out on Operation Descriptions that are too long, but I personally want or need very descriptive Operation naming.
If it can't break these into multiple lines, is there a way to eliminate comment lines that are over a certain length, from being output?
Thank you all for the help
Replies (9)
rich5
For max feed.
Here is one way using a, if feed is greater the 500 then say the feed is 500, this is using if end statements.MAX FEED.png
On help in post processer utility, click on contents, go to tab search, search operators, click on Assigning expressions to parameters.
you should see a topic based on this. (probably the right way to do it)
Feed Rate = max ( %p(Feed Rate)%, 100 )
kevin.hammond3WX4X
It sounds like you need to add or configure Break chip setup to output G73 cycle
Very nice, thank you both for your responses.
I will try both of these out and see if I can get it to work.
Thank you both again.
I appreciate the help...
Sean571
For max feedrates, there is a Max feed setting in the post and when you set it, it will automatically reduce the feedrate to the max, without having to add extra logic to the post.
Some posts have a settings turned on to break the connection when the feed is over the Max rate, so we just need to check that setting and turn it to a Warning instead.
Sean Wroblewski
Applications Engineer
Sean, thank you.  That looks like it will do the trick.  I really appreciate your help.
Sean, that worked perfectly.
Thank you for the help.
Kevin, that did it for the drilling output.
Thank you for your help...
rich5
If you only want it to be used with a certain toolpath style, you can look at more if end statements like
if (%p(Toolpath Type)%=="DRILLING")
Very nice.  Thank you rich4.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
