Move model to multiple workplanes macro
iamcdn79
Mentor Mentor
iamcdn79
I have an existing macro that I want to change to move the model to multiple workplane locations instead of just one that I currently have.
This macro works if I just select one workplane but if I select more than one it errors on line
ACTIVATE WORKPLANE $wp.Name
This is what I have currently
STRING yourworkplanename = "G54","G55","G56","G57","G58","G59"
IF ENTITY_EXISTS('workplane', $yourworkplanename) {
//Do Nothing
	} ELSE {
		GRAPHICS LOCK
      // 	CREATE WORKPLANE AT G54
MODE WORKPLANE_CREATE "G54" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -6.0493 -14.5758 0
		// CREATE WORKPLANE AT G55
MODE WORKPLANE_CREATE "G55" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -6.0493 -6.7024 0
 //CREATE WORKPLANE AT G56
MODE WORKPLANE_CREATE "G56" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -15.8944 -14.5758 0
//CREATE WORKPLANE AT G57
MODE WORKPLANE_CREATE "G57" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -15.8944 -6.7024 0
//CREATE WORKPLANE AT G58
MODE WORKPLANE_CREATE "G58" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -25.3346 -12.3245 0
//CREATE WORKPLANE AT G59
MODE WORKPLANE_CREATE "G59" INTERACTIVE POINT
MODE COORDINPUT COORDINATES -25.3346 -7.4026 0
UNDRAW WORKPLANE ALL
GRAPHICS UNLOCK
/ ENTITY LIST
ENTITY LIST $Model = INPUT ENTITY MODEL "Select Which Model To Copy To Fixture Offset"
STRING $Newmodel = new_entity_name('model')
STRING $folderFull = "Model\" + $Model.Name
// Allow selection of multiple workplanes
ENTITY LIST $wpNames = INPUT ENTITY MULTIPLE WORKPLANE "Select The Fixture Offsets To Move The Model To"
FOREACH wp IN $wpNames {
  // Activate current workplane
  ACTIVATE WORKPLANE $wp.Name <----- THIS LINE ERRORS ON ME WHEN NEEDING TO ACTIVATE SECOND SELECTED WORKPLANE FROM INPUT LIST
  // Store workplane name for later use
  STRING $currentWpName = $wp.Name
  IF NOT folder_exists($folderFull) {
    CREATE FOLDER "Model" $Model.Name
  ACTIVATE FOLDER $folderFull
  EDIT MODEL $Model.Name CLIPBOARD COPY
  CREATE MODEL CLIPBOARD
  TRANSFORM TYPE WORKPLANE TRANSFORM MODEL $Newmodel
  DEACTIVATE WORKPLANE
  // Unique naming based on model and workplane
  STRING $newName = $Model.Name + "_" + $currentWpName
  INT $i = 1
  WHILE ENTITY_EXISTS('model', $newName) {
    $newName = $newName + "_" + $i
    $i = $i + 1
  RENAME MODEL $Newmodel $newName
  EDIT MODEL $newName SELECT ALL
  // Check if "Moved" level exists
 IF NOT ENTITY_EXISTS('level',"Moved Models to Fixture Offset") {
   CREATE LEVEL "Moved Models to Fixture Offset" Level
 EDIT LEVEL "Moved Models to Fixture Offset" ACQUIRE SELECTED
 DEACTIVATE FOLDER $folderFull
QUIT
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
icse
i currently dont have a powermill licence so i can't debug your code...
This lines confuses me, it looks like you try to create a list of string but the LIST keyword is missing so do the {}.
In your state the IF statement probably only checks the if the G54 Workplane exists(i guess the yourworkplane variable is just "G54")
next this,
first line misses one /
second got the list keyword but on the right side the MULTIPLE keyword is missing.
/ ENTITY LIST
for the line that errors you you could try to set the wp.Name into {} like this:
ACTIVATE WORKPLANE ${wp.Name}
hope this helps, can't do more atm sorry.
iamcdn79
1) Ok good catch, made the necessary change to
STRING LIST yourworkplanenames = {"G54","G55","G56","G57","G58","G59"}
FOREACH wpname IN yourworkplanenames {
  IF ENTITY_EXISTS('workplane', $wpname) {
// ... rest of code ...
2) I missed highlighting the second / in the code
I only want to select one model instead of multiple
3)
also errors when activating the second workplane
Windows 11 Pro
Sean571
Hmm I know it's not the syntax that is causing an error like this as a simplified foreach loop will work just fine if this is all that is in a macro:
    message info $wp.Name
    deactivate workplane
So the only thing I that comes to mind is that something in your foreach loop is putting PowerMill into some type of error state or a state in which Activating a workplane isn't allowed. Might be similar to what happens when you try to save your project when you are in the curve editor. You'd get this error:
Can you repost the entire macro with all the changes you made, so I can test with what you have right now?
Otherwise I'd be curious if you got the same error if you replaced your foreach loop with this loop instead-keeping all the other commands above it.
If you still get an error then we know that it's being caused by something that you are doing in the previous lines in the macro. If you don't get an error then we know that the issues is to do with something in the foreach loop.
Sean Wroblewski
Applications Engineer
iamcdn79
So I don't know what happened but this works for me now unless I had a messed up line that I didn't change after using @icse recommendation
//Do Nothing
	} ELSE {
		GRAPHICS LOCK
GRAPHICS UNLOCK
// ENTITY LIST
  INT $i = 1
    $i = $i + 1
EDIT MODEL ALL DESELECT ALL
QUIT
DEACTIVATE WORKPLANE $wpName
QUIT
Windows 11 Pro
icse
Sometimes powermill get stuck/behaves strange after you got some errors while debugging.
