macros that are running javascript
nozby
Message 1 of 8
nozby
Hello all,
I was hoping that someone can help me with this:
I have some macros that are running javascript or VBS.
They can be lunch from a regular MAC file like any other macro using a link like this:
      pmillhelp url fille:///C:\PM_Macro\test\example.html
All macros look pretty much the same. Something like this:
html>
<head>
<script language = "javascript">
  var PowerMill = top.external;
      function apply_click() {
         PowerMill.Execute("Do some work",1);
</script>
</head>
<body>
<form>
<input type = 'button' name = 'button' value = 'apply' OnClick = 'apply_click();'/>
</form>
</body>
</html>
My problem is that they all need a button to lunch the script, and I can't figure out how do I create something that runs just by lunching the MAC file, which contains the link to that script. In other words, how can I eliminate the button from my programs?
I hope I am explaining my problem clearly enough.
Thank you for your help.
Replies (7)
Message 2 of 8
Try this:
<html>
<head>
  PowerMill.Execute("MESSAGE INFO 'Javascript running'",1);
</script>
</head>
<body>
</body>
</html>
Message 3 of 8
nozby
Thank you for your response, but that's what I'm trying to do and somehow can't make it work. Also, the SPLITTER TABBROWSER keeps opening, and I don't know how to prevent that.
Message 4 of 8
<html>
<head>
  PowerMill.Execute("BROWSER HOME",1);
  PowerMill.Execute("SPLITTER TABEXPLORE",1);
  PowerMill.Execute("EXPLORER SELECT Workplane 'Workplane\\1p' NEW",1);
  </script>
</head>
<body>
</body>
</html>
Message 5 of 8
nozby
I'm still doing something wrong. I even copied your code just to make sure I got it right. It is not working.
Message 6 of 8
Sorry, I only tested from the command line, it worked that way, but it doesn't really work from a macro call. Specifically, javascript runs but does not set the PowerMill variable well. To eliminate the problem
I did the following: I downloaded AutoIt v3 https://www.autoitscript.com/site/autoit/  and made it
a script
#include-once
#include <WinAPI.au3>
#include <Memory.au3>
#include <WinAPISys.au3>
#include <WinAPIFiles.au3>
#include <MsgBoxConstants.au3>
Local $DropFile=""
If $CmdLine[0] = 0 Then
   $DropFile="c:\temp\test.html"
Else
   $Dropfile=$CmdLine[1]
EndIf
If Not FileExists($DropFile) Then
   MsgBox($MB_SYSTEMMODAL, "Drag&Drop", "File not found -" & $DropFile, 10)
   Exit
 EndIf
 Local $tPointStruct = _WinAPI_GetMousePos ()
 Local $hWndDragDropTarget = _WinAPI_WindowFromPoint($tPointStruct)
 Local $aWindows = _WinAPI_EnumWindows()
 For $i = 1 To $aWindows[0][0]
   If _WinAPI_IsChild ($hWndDragDropTarget, $aWindows[$i][0] ) Then
      $hWndDragDropTarget = $aWindows[$i][0]
	  ExitLoop
   EndIf
 Next
 $tPointStruct = _WinAPI_GetMousePos (True, $hWndDragDropTarget)
 _FileDragDrop($hWndDragDropTarget,$DropFile,DllStructGetData($tPointStruct, "x"),DllStructGetData($tPointStruct, "y"))
Exit
that performs a drag & drop operation The original code . This also works well from HTML + javascript macro calls. For security reasons, I uploaded the source code, if you want to try it, compile it.
You have to rewrite the file paths, I used the c:\temp folder
Message 7 of 8
Oops! double post
Message 8 of 8
nozby
That help. Thank you.
