Macro Tool DB with Material
gosmann.andreas
gosmann.andreas
whats wrong it tells me there the Material not in the DB
STRING $Material = ""
STRING LIST $Options = {"Aluminium", "Guss", "Werkzeugstahl"}
INT $result = INPUT CHOICE $Options "Wähle das Material"
If $result == 0 {
    $Material = "Aluminium"
} ELSEIF $result == 1 {
    $Material = "Guss"
} ELSE {
    $Material = "Werkzeugstahl"
//Abfrage der Werkzeuge für M4
IF NOT $ENTITY_EXISTS('tool','HSS_NC-Anbohrer_D10,00_90Grad_YG-1_D2306100') {
   FORM TOOLDBSEARCH
   TOOLDB QUERY SET TOOL_TYPE ALL
   TOOLDB QUERY SET STOCK_MATERIAL_ACTIVE
   TOOLDB STOCK_MATERIAL SELECT "$Material"
   TOOLDB QUERY SET NAME "HSS_NC-Anbohrer_D10,00_90Grad_YG-1_D2306100"
   TOOLDB QUERY PRESET
   TOOLDB RESULTS_LIST CREATE NOQUIBBLE ALL
IF NOT $ENTITY_EXISTS('tool','HSS_Bohrer_D03,30_L36_Gold-P') {
   FORM TOOLDBSEARCH
   TOOLDB QUERY SET NAME "HSS_Bohrer_D03,30_L36_Gold-P"
   TOOLDB QUERY PRESET
IF NOT $ENTITY_EXISTS('tool','Gewindebohrer_M4x0,7') {
   FORM TOOLDBSEARCH
   TOOLDB QUERY SET NAME "Gewindebohrer_M4x0,7"
   TOOLDB QUERY PRESET
   TOOLDBSEARCH ACCEPT
rafael.sansao
try this:
TOOLDB STOCK_MATERIAL SELECT $Material
Rafael Sansão
OptiNC - www.optinc.tech
gosmann.andreas
i tried that dont work
rafael.sansao
I tested on the Powermill 2020 and 2021 and it works. Which version are you using?
If $result == 0 {
    $Material = "Guss"
} ELSE {
   FORM TOOLDBSEARCH
   TOOLDB QUERY PRESET
Rafael Sansão
gosmann.andreas
i dont know why but i cloesed everything reopend it and it works without ""
thank you
