MACRO TO RECORD IN EXTERNAL .TXT FILE
moraschini
Message 1 of 11
moraschini
hello Everyone and happy new year.
do someone know a way to "record" what appear in the echo box or a macro execution with the variabile copiled to an external file?
thanks in advance for the help
Replies (10)
Message 2 of 11
iamcdn79
Right click on 'Macros' click record and select the dir and name to record as a .mac file
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 11
moraschini
hello @iamcdn79 ,thanks for the replay.
before post this i tested in the way you told me but this method don't give me result i want.
in this way it keep the variable write as variable, but my idea was see in this file the value that the variable get.
Message 4 of 11
icse
You could use the debugging tool, or just print the variable like:
print ${myVar}
or use a messagebox popup like:
message info $myVar
Message 5 of 11
moraschini
hello @icse ,
do i have to put
print ${myVar}
for every var that i have in my macro or it's possible write it only one time at the start and for every var i have in the macro it print it?
Message 6 of 11
icse
Whats your goal? Can you share the macro?
Maybe you should give the debug tool a try
Message 7 of 11
moraschini
this is my macro and i already do the record while it's running, but my idea was see the value that every variable keep during the macro execution
//compile statistics file for powermill
function main(){
	//------------------------------TRACE DELLA MACRO---------------------------------------
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	MACRO RECORD FILESAVE "V:\3D\PowerMILL\Statistics\statistics_exporting_trace.mac" Yes
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	string $date = local_time(time()).day + "-" +  local_time(time()).month + "-"+ local_time(time()).year
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	IF NOT Member(local._keys,"Statistics_exported") {
		EDIT USERPAR project  TYPE 'Real'
		EDIT USERPAR project NAME "Statistics_exported"
		CREATE USERPAR project
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	//lettura file
	STRING LIST $statistics = {}
	STRING $OPENFILE = "FILE OPEN V:\3D\PowerMILL\Statistics\Statistics.txt FOR READ AS input"
	DOCOMMAND $OPENFILE
	FILE READ $statistics FROM input
	FILE CLOSE input
	if $Stats == 1 {
		call only_view($statistics)
		return
	string list $month_list = {'GENNAIO','FEBBRAIO','MARZO','APRILE','MAGGIO','GIUGNO','LUGLIO','AGOSTO','SETTEMBRE','OTTOBRE','NOVEMBRE','DICEMBRE'}
	//reading from previous
	int $a = 4
	int $b = $a + 12
	int $c = $b + 12
	int $d = $c + 12
	int $e = $d + 12
	//string $msg = $statistics[$a + 2 ]
	//MESSAGE INFO $msg
	string $giorno_corrente = substring($statistics[$a] , (position($statistics[$a] , "=") + 2) , (length($statistics[$a]) - position($statistics[$a] , "=") + 1 ))	//a
		real $hl_d = real(substring($statistics[$a + 2] , 0 , position($statistics[$a + 2],"=")))													//ore lavoro totali
		real $nt_d = real(substring($statistics[$a + 3] , 0 , position($statistics[$a + 3],"=")))  												//numero utensili totali
		real $cx_d = real(substring($statistics[$a + 4] , 0 , position($statistics[$a + 4],"=")))													//numero cinque assi
		real $cxk_d = real(substring($statistics[$a + 5] , 0 , position($statistics[$a + 5],"=")))												//numero cinque assi k
		real $cxh_d = real(substring($statistics[$a + 6] , 0 , position($statistics[$a + 6],"=")))												//numero cinque assi h
		real $pc_d = real(substring($statistics[$a + 7] , 0 , position($statistics[$a + 7],"=")))													//powermill completi
		real $md_d = real(substring($statistics[$a + 8] , 0 , position($statistics[$a + 8],"=")))													//cuori
		real $all_d = real(substring($statistics[$a + 9] , 0 , position($statistics[$a + 9],"=")))												//allargatori
		real $mt_d = real(substring($statistics[$a + 10] , 0 , position($statistics[$a + 10],"=")))												//matrici
	string $mese_corrente = substring($statistics[$b] , (position($statistics[$b] , "=") + 2) , (length($statistics[$b]) - position($statistics[$b] , "=") + 1 ))	//b
		real $hl_m = real(substring($statistics[$b + 2] , 0 , position($statistics[$b + 2],"=")))													//ore lavoro totali
		real $nt_m = real(substring($statistics[$b + 3] , 0 , position($statistics[$b + 3],"=")))  												//numero utensili totali
		real $cx_m = real(substring($statistics[$b + 4] , 0 , position($statistics[$b + 4],"=")))													//numero 5 assi
		real $cxk_m = real(substring($statistics[$b + 5] , 0 , position($statistics[$b + 5],"=")))												//numero 5 assi k
		real $cxh_m = real(substring($statistics[$b + 6] , 0 , position($statistics[$b + 6],"=")))												//numero 5 assi h
		real $pc_m = real(substring($statistics[$b + 7] , 0 , position($statistics[$b + 7],"=")))													//powermi5 completi
		real $md_m = real(substring($statistics[$b + 8] , 0 , position($statistics[$b + 8],"=")))													//cuori
		real $all_m = real(substring($statistics[$b + 9] , 0 , position($statistics[$b + 9],"=")))												//allargatori
		real $mt_m = real(substring($statistics[$b + 10] , 0 , position($statistics[$b + 10],"=")))												//matrici
	string $anno_corrente = substring($statistics[$c] , (position($statistics[$c] , "=") + 2) , (length($statistics[$c]) - position($statistics[$c] , "=") + 1 ))	//c
		real $hl_a = real(substring($statistics[$c + 2] , 0 , position($statistics[$c + 2],"=")))													//ore lavoro totali
		real $nt_a = real(substring($statistics[$c + 3] , 0 , position($statistics[$c + 3],"=")))  												//numero utensili totali
		real $cx_a = real(substring($statistics[$c + 4] , 0 , position($statistics[$c + 4],"=")))													//numero 5 assi
		real $cxk_a = real(substring($statistics[$c + 5] , 0 , position($statistics[$c + 5],"=")))												//numero 5 assi k
		real $cxh_a = real(substring($statistics[$c + 6] , 0 , position($statistics[$c + 6],"=")))												//numero 5 assi h
		real $pc_a = real(substring($statistics[$c + 7] , 0 , position($statistics[$c + 7],"=")))													//powermi5 completi
		real $md_a = real(substring($statistics[$c + 8] , 0 , position($statistics[$c + 8],"=")))													//cuori
		real $all_a = real(substring($statistics[$c + 9] , 0 , position($statistics[$c + 9],"=")))												//allargatori
		real $mt_a = real(substring($statistics[$c + 10] , 0 , position($statistics[$c + 10],"=")))												//matrici
	string $mese_precedente = substring($statistics[$d] , (position($statistics[$d] , "=") + 2) , (length($statistics[$d]) - position($statistics[$d] , "=") + 1 )) //d
		real $hl_mp = real(substring($statistics[$d + 2] , 0 , position($statistics[$d + 2],"=")))												//ore lavoro totali
		real $nt_mp = real(substring($statistics[$d + 3] , 0 , position($statistics[$d + 3],"=")))  												//numero utensili totali
		real $cx_mp = real(substring($statistics[$d + 4] , 0 , position($statistics[$d + 4],"=")))												//numero 5 assi
		real $cxk_mp = real(substring($statistics[$d + 5] , 0 , position($statistics[$d + 5],"=")))												//numero 5 assi k
		real $cxh_mp = real(substring($statistics[$d + 6] , 0 , position($statistics[$d + 6],"=")))												//numero 5 assi h
		real $pc_mp = real(substring($statistics[$d + 7] , 0 , position($statistics[$d + 7],"=")))												//powermill completi
		real $md_mp = real(substring($statistics[$d + 8] , 0 , position($statistics[$d + 8],"=")))												//cuori
		real $all_mp = real(substring($statistics[$d + 9] , 0 , position($statistics[$d + 9],"=")))												//allargatori
		real $mt_mp = real(substring($statistics[$d + 10] , 0 , position($statistics[$d + 10],"=")))												//matrici
	string $anno_precedente = substring($statistics[$e] , (position($statistics[$e] , "=") + 2) , (length($statistics[$e]) - position($statistics[$e] , "=") + 1 ))	//e
		real $hl_ap = real(substring($statistics[$e + 2] , 0 , position($statistics[$e + 2],"=")))												//ore lavoro totali
		real $nt_ap = real(substring($statistics[$e + 3] , 0 , position($statistics[$e + 3],"=")))  												//numero utensili totali
		real $cx_ap = real(substring($statistics[$e + 4] , 0 , position($statistics[$e + 4],"=")))												//numero 5 assi
		real $cxk_ap = real(substring($statistics[$e + 5] , 0 , position($statistics[$e + 5],"=")))												//numero 5 assi k
		real $cxh_ap = real(substring($statistics[$e + 6] , 0 , position($statistics[$e + 6],"=")))												//numero 5 assi h
		real $pc_ap = real(substring($statistics[$e + 7] , 0 , position($statistics[$e + 7],"=")))												//powermill completi
		real $md_ap = real(substring($statistics[$e + 8] , 0 , position($statistics[$e + 8],"=")))												//cuori
		real $all_ap = real(substring($statistics[$e + 9] , 0 , position($statistics[$e + 9],"=")))												//allargatori
		real $mt_ap = real(substring($statistics[$e + 10] , 0 , position($statistics[$e + 10],"=")))												//matrici
	//refresh
	string $day = local_time(time()).day
	string $month = local_time(time()).month
	string $year = local_time(time()).year
	string $new_giorno_corrente = replace($statistics[$a] , $giorno_corrente , $date)
	string $new_mese_corrente = replace($statistics[$b] , $mese_corrente , $month_list[real($month) - 1])
	string $new_anno_corrente = replace($statistics[$c] , $anno_corrente , int($year))
	int $mp = int($month) - 2
	if ($mp < 0) {
		$mp = 13 + $mp
	string $new_mese_precedente = replace($statistics[$d] , $mese_precedente , $month_list[$mp - 1])
	string $new_anno_precedente = replace($statistics[$e] , $anno_precedente , int($year)-1)
	real $TOTAL_TIME = 0
	int $ntool = 0
	call TOTAL_MACHINING_TIME($TOTAL_TIME , $ntool)
	//string $hl_d_n  = time_to_string($TOTAL_TIME,"M")
	real $hl_d_n  = $TOTAL_TIME
	real $nt_d_n  = $ntool
	bool $cx_d_n  = (int(multiaxis) != 0)
	bool $cxk_d_n = ((int(multiaxis) == 1) or (int(multiaxis) == 2))
	bool $cxh_d_n = ((int(multiaxis) == 3) or (int(multiaxis) == 4))
	bool $pc_d_n  =	(ENTITY_EXISTS("Toolpath", "ZONE 5 DEGREE FIN") OR ENTITY_EXISTS("Toolpath", "ZONE 3 DEGREE FIN") OR ENTITY_EXISTS("Toolpath", "ZONE 2 DEGREE FIN") OR ENTITY_EXISTS("Toolpath", "ZONE 6 CIL FIN") OR ENTITY_EXISTS("Toolpath", "ZONE 12 CIL FIN"))
	bool $md_d_n  = (ENTITY_EXISTS("Level", "264") and ENTITY_EXISTS("Level", "260") and ($multiaxis == 0))
	bool $all_d_n = (ENTITY_EXISTS("Level", "264")and not ENTITY_EXISTS("Level", "260") and ($multiaxis == 0))
	bool $mt_d_n  = (ENTITY_EXISTS("Level", "20"))
	if (int($anno_corrente) != int($year)) {
		//previously year
		$hl_ap 	= $hl_a
		$nt_ap 	= $nt_a
		$cx_ap 	= $cx_a
		$cxk_ap	 = $cxk_a
		$cxh_ap	 = $cxh_a
		$pc_ap	= $pc_a
		$md_ap 	= $md_a
		$all_ap	 = $all_a
		$mt_ap 	= $mt_a
	if ($mese_corrente != $month_list[real($month) - 1]) {
		//previously month
		$hl_mp 	= $hl_m
		$nt_mp 	= $nt_m
		$cx_mp 	= $cx_m
		$cxk_mp	 = $cxk_m
		$cxh_mp	 = $cxh_m
		$pc_mp	= $pc_m
		$md_mp 	= $md_m
		$all_mp	 = $all_m
		$mt_mp 	= $mt_m
	if ($date != $giorno_corrente) {
		//previously month
		$hl_d =  0
		$nt_d =  0
		$cx_d =  0
		$cxk_d = 0
		$cxh_d = 0
		$pc_d =  0
		$md_d =  0
		$all_d = 0
		$mt_d =  0
	// updating value
	//current day
	$hl_d 	= (round(($hl_d + $hl_d_n) * 100 , 0)) / 100
	$nt_d 	= $nt_d 	+ $nt_d_n
	$cx_d 	= $cx_d 	+ $cx_d_n
	$cxk_d	 = $cxk_d	+ $cxk_d_n
	$cxh_d	 = $cxh_d	+ $cxh_d_n
	$pc_d 	= $pc_d 	+ $pc_d_n
	$md_d 	= $md_d 	+ $md_d_n
	$all_d	 = $all_d	+ $all_d_n
	$mt_d 	= $mt_d 	+ $mt_d_n
	//current month
	$hl_m 	= (round(($hl_m + $hl_d) * 100 , 0)) / 100
	$nt_m 	= $nt_m 	+ $nt_d_n
	$cx_m 	= $cx_m 	+ $cx_d_n
	$cxk_m	 = $cxk_m	+ $cxk_d_n
	$cxh_m	 = $cxh_m	+ $cxh_d_n
	$pc_m 	= $pc_m 	+ $pc_d_n
	$md_m 	= $md_m 	+ $md_d_n
	$all_m	 = $all_m	+ $all_d_n
	$mt_m 	= $mt_m 	+ $mt_d_n
	//current year
	$hl_a 	= (round(($hl_a + $hl_d) * 100 , 0)) / 100
	$nt_a 	= $nt_a 	+ $nt_d_n
	$cx_a 	= $cx_a 	+ $cx_d_n
	$cxk_a	 = $cxk_a	+ $cxk_d_n
	$cxh_a	 = $cxh_a	+ $cxh_d_n
	$pc_a 	= $pc_a 	+ $pc_d_n
	$md_a 	= $md_a 	+ $md_d_n
	$all_a	 = $all_a	+ $all_d_n
	$mt_a 	= $mt_a 	+ $mt_d_n
	string $new_text = ""
	int $kk = 0
	foreach item in $statistics {
		string $add_txt = item
		string $add_txt_value = substring($add_txt , 0 , position($add_txt , "="))
		string $add_txt_description = substring($add_txt , position($add_txt , "=") , (length($add_txt) - position($add_txt , "=")))
		//MESSAGE INFO ($kk + crlf + item)
		switch $kk {
			case 4
				$add_txt = $new_giorno_corrente
			break
			case 6
				$add_txt = string($hl_d) + $add_txt_description
			break
			case 7
				$add_txt = string(int($nt_d)) + $add_txt_description
			break
			case 8
				$add_txt = string(int($cx_d)) + $add_txt_description
			break
			case 9
				$add_txt = string(int($cxk_d)) + $add_txt_description
			break
			case 10
				$add_txt = string(int($cxh_d)) + $add_txt_description
			break
			case 11
				$add_txt = string(int($pc_d)) + $add_txt_description
			break
			case 12
				$add_txt = string(int($md_d)) + $add_txt_description
			break
			case 13
				$add_txt = string(int($all_d)) + $add_txt_description
			break
			case 14
				$add_txt = string(int($mt_d)) + $add_txt_description
			break
			case 16
				$add_txt = $new_mese_corrente
			break
			case 18
				$add_txt = string($hl_m) + $add_txt_description
			break
			case 19
				$add_txt = string(int($nt_m)) + $add_txt_description
			break
			case 20
				$add_txt = string(int($cx_m)) + $add_txt_description
			break
			case 21
				$add_txt = string(int($cxk_m)) + $add_txt_description
			break
			case 22
				$add_txt = string(int($cxh_m)) + $add_txt_description
			break
			case 23
				$add_txt = string(int($pc_m)) + $add_txt_description
			break
			case 24
				$add_txt = string(int($md_m)) + $add_txt_description
			break
			case 25
				$add_txt = string(int($all_m)) + $add_txt_description
			break
			case 26
				$add_txt = string(int($mt_m)) + $add_txt_description
			break
			case 28
				$add_txt = $new_anno_corrente
			break
			case 30
				$add_txt = string($hl_a) + $add_txt_description
			break
			case 31
				$add_txt = string(int($nt_a)) + $add_txt_description
			break
			case 32
				$add_txt = string(int($cx_a)) + $add_txt_description
			break
			case 33
				$add_txt = string(int($cxk_a)) + $add_txt_description
			break
			case 34
				$add_txt = string(int($cxh_a)) + $add_txt_description
			break
			case 35
				$add_txt = string(int($pc_a)) + $add_txt_description
			break
			case 36
				$add_txt = string(int($md_a)) + $add_txt_description
			break
			case 37
				$add_txt = string(int($all_a)) + $add_txt_description
			break
			case 38
				$add_txt = string(int($mt_a)) + $add_txt_description
			break
			case 40
				$add_txt = $new_mese_precedente
			break
			case 42
				$add_txt = string($hl_mp) + $add_txt_description
			break
			case 43
				$add_txt = string(int($nt_mp)) + $add_txt_description
			break
			case 44
				$add_txt = string(int($cx_mp)) + $add_txt_description
			break
			case 45
				$add_txt = string(int($cxk_mp)) + $add_txt_description
			break
			case 46
				$add_txt = string(int($cxh_mp)) + $add_txt_description
			break
			case 47
				$add_txt = string(int($pc_mp)) + $add_txt_description
			break
			case 48
				$add_txt = string(int($md_mp)) + $add_txt_description
			break
			case 49
				$add_txt = string(int($all_mp)) + $add_txt_description
			break
			case 50
				$add_txt = string(int($mt_mp)) + $add_txt_description
			break
			case 52
				$add_txt = $new_anno_precedente
			break
			case 54
				$add_txt = string($hl_ap) + $add_txt_description
			break
			case 55
				$add_txt = string(int($nt_ap)) + $add_txt_description
			break
			case 56
				$add_txt = string(int($cx_ap)) + $add_txt_description
			break
			case 57
				$add_txt = string(int($cxk_ap)) + $add_txt_description
			break
			case 58
				$add_txt = string(int($cxh_ap)) + $add_txt_description
			break
			case 59
				$add_txt = string(int($pc_ap)) + $add_txt_description
			break
			case 60
				$add_txt = string(int($md_ap)) + $add_txt_description
			break
			case 61
				$add_txt = string(int($all_ap)) + $add_txt_description
			break
			case 62
				$add_txt = string(int($mt_ap)) + $add_txt_description
			break
		if $new_text == "" {
			$new_text = $add_txt
		} else {
			$new_text = $new_text + crlf + $add_txt
			//INFOBOX NEW "Statistics"
			//INFOBOX APPEND $new_text
		$kk = $kk + 1
//	INFOBOX NEW "Statistics"
//	INFOBOX APPEND $new_text
	if (int($Statistics_exported) == 0) {
		FILE OPEN "V:\3D\PowerMILL\Statistics\Statistics.txt" FOR write AS out
		FILE WRITE $new_text TO out
		FILE CLOSE out
		//MESSAGE INFO "Statistics_exported"
		$Statistics_exported = 1
	//------------------------------END TRACE---------------------------------------
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	MACRO STOP
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
FUNCTION TOTAL_MACHINING_TIME(output real $TOTAL_TIME , output int $ntool) {
	$TOTAL_TIME = 0
	$ntool = 0
	REAL $F_TIME = 0
	STRING LIST $Folder = $GET_FOLDERS('toolpath')
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	$Folder = remove($Folder , "Toolpath\GHOST")
	$Folder = remove($Folder , "Toolpath\GHOST ")
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	FOREACH f IN $FOLDER {
		// Make the FOLDER name bold & underlined
		STRING $FN = SUBSTRING (f,9)
		STRING msg =  $FN
		FOREACH TP IN FOLDER ($f) {
			STRING $TPN = TP.NAME
			REAL $TPTIME = TP.STATISTICS.TOTALTIME
			$F_TIME = $F_TIME + $TPTIME
			$TOTAL_TIME = $TOTAL_TIME + $TPTIME
			$ntool = $ntool + 1
FUNCTION only_view(STRING LIST $statistics) {
	int $kk = 0
		if kk >= 4 {
			string $add_txt2 = ''
			if $kk == 14 {
				real $a = substring($statistics[6] , 0 , position($statistics[6] , "="))
				$a = $a / 1440
				real $d = $a
				real $h = ($d - int($d)) * 24
				real $m = ($h - int($h)) * 60
				real $s = ($m - int($m)) * 60
				$add_txt2 = int($d) + " giorni " +  int($h) + " ore " +  int($m) + " minuti " +  int($s) + " secondi"
			if $kk == 26 {
				real $a = substring($statistics[18] , 0 , position($statistics[18] , "="))
				$a = $a / 1440
				real $d = $a
			if $kk == 38 {
				real $a = substring($statistics[30] , 0 , position($statistics[30] , "="))
				$a = $a / 1440
				real $d = $a
			} elseif $add_txt2 == "" {
			} else {
				$new_text = $new_text + crlf + $add_txt + crlf + $add_txt2
		$kk = $kk + 1
	DIALOGS MESSAGE OFF
	DIALOGS ERROR OFF
	MACRO STOP
	DIALOGS MESSAGE ON
	DIALOGS ERROR ON
	MACRO PAUSE "REBOOT WHEN OK"
Message 8 of 11
icse
you can see every variable in the debugger:
Message 9 of 11
moraschini
i know.
i need a file like the macro record create but with the variable replaced by the value that keep. without running the debug, if it's possible
Message 10 of 11
icse
for exampe you whant this code part:
Printed to a text file like this:
real 207.6 = (10.65 - int(2.65)) * 24
ofc for the whole macro
Message 11 of 11
moraschini
yes, something like that
