PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Macro to make measurements
2 REPLIES 2
1225 Views, 2 Replies
Good Morning
Overview ;
I am a very, very forgetful man and I have a habit of forgetting to include some data with my line up sheets. Usually parallel sizing or distance from a face of a vise.
I would like to get around this by having a macro measure the distance of the bottom most part of my "PART" (see screenshot 1) and a pre-defined work plane, then spitting this data out to something I can store and call out on my setup sheet.
My measurement work plane (The active one) is static and will always be available. In my PowerMill session it is a point called "Measurement"
My PART measurement point will be dynamic. I'd like to have that assigned by the "Create workplane from block - Block Edge". The problem with that is the pick command.
I feel like there are likely some macro commands that will omit clicking entirely that will be what I'm looking for.
To break it down process wise;
Activate Workplane "Measurement"
Create Workplane based on the Y- block edge
Name this WorkPlane "Measurement - Part"
Measure relative distance between Measurement and Measurement - Part
Save Y value as "YDistance"
Save Z value as "ZDistance"
Save X value as "XDistance"
I would then like to write these values to my NC Program notes
Any and all help is appreciated. I may be going about this the wrong way entirely.
2 REPLIES 2
LasseFred
// Check to see if the project variable "XYZ_MAAL" already exists
BOOL $chk = 0
$chk = ERROR $project.XYZ_MAAL
if $chk {
// Project variable does not exist so create it!.... Use EDIT PAR CREATE STRING "XYZ_MAAL" ...... for a global STRING variable
// Edit the value of the project variable
$project.XYZ_MAAL = " [NONE] "
// Check to see if the project variable "Block_Z_MIN" already exists
BOOL $chk1 = 0
$chk1 = ERROR $project.Block_Z_MIN
if $chk1 {
// Project variable does not exist so create it!.... Use EDIT PAR CREATE STRING "Block_Z_MIN" ...... for a global STRING variable
$project.Block_Z_MIN = " [NONE] "
// FORM BLOCK
EDIT MODEL ALL DESELECT ALL
DRAW BLOCK
EDIT BLOCK RESETLIMIT "0"
EDIT BLOCKTYPE BOX
EDIT BLOCK LIMITTYPE MODEL
EDIT BLOCK RESET
REAL $BLOCK_LENGTH_X = (-1 * round(Block.Limits.XMin;3)) + round(Block.Limits.XMax;3)
REAL $BLOCK_LENGTH_Y = (-1 * round(Block.Limits.YMin;3)) + round(Block.Limits.YMax;3)
REAL $BLOCK_LENGTH_Z = (-1 * round(Block.Limits.ZMin;3)) + round(Block.Limits.ZMax;3)
REAL $BLOCK_MIN_Z = (round(Block.Limits.ZMin;3))
$project.XYZ_MAAL = "FÆRDIG MÅL : X " + $BLOCK_LENGTH_X + " Y " + $BLOCK_LENGTH_Y + " Z " + $BLOCK_LENGTH_Z
$project.Block_Z_MIN = $BLOCK_MIN_Z
UNDRAW BLOCK
BLOCK CANCEL
BLOCK CANCELLED
it makes project variables
______________________
Lasse F.
in reply to: LasseFred
Saving the block dimensions as a variable is something we already do so I'm turbo-dumb for missing it as a valid way to measure two points.
Thanks!
