Macro to import .dmt model into the block
Hi everyone, I need help with a macro again, which I am attaching.
Basically I want to export the residual material model in the "Model" folder of the current project and this macro does it perfectly.
Then I would like to import it as triangles in the block to be able to use it in the simulation.
In the last step, the macro fails and fails to import the model.
Thanks for your help
Sorry, I found the solution was enough to search the forum ...
