Macro to Auto adjust Overhang, using holder profile
Sean570
Sean570
I've got a macro that will calculate the holder profile for all tools being used. The issue I have is when I add a line of code auto adjust the overhang based on the holder profile. It works just fine, until it comes across a locked tools. So I have been trying to get something to detect that the tool is locked, and if so, not calculate the overhang.
I have used ERROR DOCOMMAND in the past to catch things like this, but I can't seem to get the syntax right for DOCOMMAND to work properly. I am using powermill 2015
Here's what I have, any ideas would be appreciated:
ENTITY LIST usedTools = {}
$usedTools = extract(folder('toolpath'), 'tool')
INT Duplicates = 0
$Duplicates = remove_duplicates($usedTools)
FOREACH tool IN $usedTools {
    EDIT TOOL $tool PROFILE_INCLUDE_ALL
    EDIT TOOL $tool UPDATE_TOOLPATHS_PROFILE
    BOOL error = 0
    STRING toolName = $tool.name
    STRING cmd = "EDIT TOOL" + $toolName + "AUTO_OVERHANG"
    $error = ERROR DOCOMMAND $cmd
    IF NOT $error {
       EDIT TOOL $toolName AUTO_OVERHANG
mark.sully
Try this:
ENTITY LIST usedTools = extract(folder('toolpath'), 'tool')
INT Duplicates = remove_duplicates($usedTools)
FOREACH t IN $usedTools {
  EDIT TOOL $t.Name PROFILE_INCLUDE_ALL
  EDIT TOOL $t.Name UPDATE_TOOLPATHS_PROFILE
  IF NOT locked($t.Diameter) {
    EDIT TOOL $t.Name AUTO_OVERHANG
The locked() function checks if a parameter is locked (tool diameter is a good check if a tool is locked).
Hope this helps.
Mark
PS. I also changed your variable name in the loop from 'tool' to 't' as it isn't good practice to use variables with the same name as PowerMill entities.
Sean570
Thanks! That works perfectly. I searched through the parameters/functions many times but it seems I missed that one. I just adjusted the macro to check if the overhang is locked instead of the diameter.
  INT Duplicates = 0
    FOREACH tl IN $usedTools {
    EDIT TOOL $tl.Name PROFILE_INCLUDE_ALL
    EDIT TOOL $tl.Name UPDATE_TOOLPATHS_PROFILE
    IF NOT locked($tl.Overhang) {
      EDIT TOOL $tl.Name AUTO_OVERHANG
mayankpatel5523
Please, create this macro for single toolpath
