MACRO : Serial Number in toolpath.
Message 1 of 10
Is there any macro available for put value/ alphabets before or after toolpath name?
Its should be in serial/sequence wise. Like below image.
regards,
 Krupal vala
Replies (9)
Message 2 of 10
5axes
like this one ?
// Permet de renuméroter les parcours
// avec X) nom du parcours
GRAPHICS LOCK
//RAZ TPNUM
INT $TPNUM = 0
STRING $TPNUMS = ""
FOREACH tp IN folder ('TOOLPATH') {
$TPNUM = $TPNUM + 1
IF $TPNUM < 10 {
	$TPNUMS = "0" + STRING($TPNUM)
} ELSE {
	$TPNUMS = STRING($TPNUM)
STRING $NEWNAME = ""
REAL $CharSep = 0
ACTIVATE TOOLPATH $tp.Name
$CharSep = position($tp.Name, ")")
// Test if ')' is present in the name or if it's present but after a theoretical XXX) position
IF $CharSep == -1 OR $CharSep >4 {
   STRING $ADDUNDER = ") " + $tp.Name
   RENAME TOOLPATH ; $ADDUNDER
$CharSep = position($tp.Name, ") ")
$CharSep = $CharSep + 1
STRING $DEL = substring($tp.Name , 0, $CharSep)
PRINT $DEL
$NEWNAME = replace(tp.Name, $DEL, $TPNUMS + ')')
RENAME TOOLPATH ; $NEWNAME
GRAPHICS UNLOCK
MESSAGE INFO "END OF PROCESS"
Message 3 of 10
thanx @5axes
result.PNGSmiley Happy
Message 4 of 10
Pradipio
Autodesk Support
Autodesk Support
hi @5axes,
Your Macro for Rename is working fine for First trail, But If i select 2nd time by mistake it will again regenerate Sequence no. with old one.
Please find attached image for your reference.
also i attached one Rename toolpath utilities, but unfortunately it was working till 2017 version only.
If you have any Utility / Macro please share.
#PM
THANKS
Pradip Mistry
”Community
Message 5 of 10
hi @Pradipio
it try & same thing happen.
@5axes is any solution available  if we make  this type of mistake ?
regards,
Krupal vala
Message 6 of 10
5axes
Normaly should be ok, Works fine for me. Even if y launch the macro several Times
Message 7 of 10
hi @Pradipio & @5axes
I try this macro in diff. diff project. some time powermill show this type of error "Powermill has stopped working" but it may due to load or other perpetrates.
even if I put 01) value before toolpath now it's not repeating & giving right sequences 01) 02) 03)...n.
@Pradipio if possible can you upload any project video what is happening???
regards,
krupal vala
Message 8 of 10
5axes
Try to change :
By
Message 9 of 10
Pradipio
Autodesk Support
Autodesk Support
hi @5axes,
not is works perfect,
Thanks for editing.
Cheers,
#PM
THANKS
Pradip Mistry
”Community
Message 10 of 10
O.C.
Is it possible to have the macro add 00 to toolpaths 1-9, 0 to toolpaths 10-99, and no zero to toolpaths 100 and up?
