You guys are so good at Macros, maybe you can help me with these two.
1) I would like to be able to invalidate all toolpaths, then calculate them all.
I have tried "queuing", but that takes forever. I just want everything calculated without having to click 90 times.
2) Gouge check and collision check for all toolpaths. (no split toolpath, 0.0 verification thickness, calculate collision depth, but do not adjust tool)
I use automatic verification on new programs, but we have a lot of old programs where automatic verification was not used.
I don't use macros as I should, so I don;t have one to give you, but I think you can solve this easily.
Request 1
On the right click menu of the tool path tab in explorer are two commands. Invalidate All and Batch Process. I believe these will do what you want.
So RMB on the MACROS tab, record, then use those two toolpath commands, then stop recording. This will give you a macro with those commands, in it. Edit the file as needed, and I think you will have what you want.
Here is the macro result I got from doing that:
INVALIDATE TOOLPATH ALL
Yes
BATCH PROCESS
Request 2
This is a little more involved, so I will defer so someone that does verification by macro.
Hope that helped a little
Steve
@Anonymous
$$invalidate all toolpaths
INVALIDATE TOOLPATH ALL YES
$$ Calculate all
BATCH PROCESS
For collision/gouge checking, we use this plugin http://autode.sk/2p5CUJm
(we are thinking of selling this in the near future ...)
Thats a nice looking plugin, did you create it yourself?
For verification we add some custome code to explorer.ppm file.
<button command='ACTIVATE Toolpath "%s" DIALOGS MESSAGE OFF FORM COLLISION EDIT COLLISION TYPE COLLISION EDIT COLLISION SHANK_CLEARANCE "0" EDIT COLLISION HOLDER_CLEARANCE "0.5" EDIT COLLISION ADJUST_TOOL N EDIT COLLISION SPLIT_TOOLPATH N EDIT COLLISION APPLY EDIT COLLISION TYPE GOUGE EDIT COLLISION APPLY COLLISION ACCEPT DIALOGS MESSAGE ON' label="Verification" multiple_selection="only" /> <button command='ACTIVATE Toolpath "%s" DIALOGS MESSAGE OFF FORM COLLISION EDIT COLLISION TYPE COLLISION EDIT COLLISION SHANK_CLEARANCE "0" EDIT COLLISION HOLDER_CLEARANCE "0.5" EDIT COLLISION ADJUST_TOOL N EDIT COLLISION SPLIT_TOOLPATH N EDIT COLLISION APPLY EDIT COLLISION TYPE GOUGE EDIT COLLISION APPLY COLLISION ACCEPT DIALOGS MESSAGE ON' label="Verification" />
This adds "Verification" option to toolpath right click menu.
You should add this code in "<!-- Toolpath Child Node Menu Start -->" (form me is line 2864)
@Anonymous
you can have you one toolpah menu
if you add toolpath.xml to your pmill4 folder, you can find some examples here in the forum.
note, you cand have all those comands in a macro, and call the macro from the menu, is easier to edit, in the menu it's bit confuse...
@Anonymous wrote:
Multiselect toolpaths with calculate and project save is the safest method.
Can you elaborate on this a bit, or give an example?
Steve
Verification macro :
Function Main(
STRING $Selected_Toolpath
ACTIVATE TOOLPATH $Selected_Toolpath
DIALOGS MESSAGE OFF
EDIT PAR 'Verification.UseVerificationThickness' 0
EDIT COLLISION HOLDER_CLEARANCE "0,5"
EDIT COLLISION DEPTH N
EDIT COLLISION STOCKMODEL_CHECK N
EDIT COLLISION SCOPE ALL
DIALOGS MESSAGE ON
calc macro:
Function Main(
EDIT PREFERENCE AUTOSAVE NO
DIALOGS MESSAGE OFF
INVALIDATE TOOLPATH $Selected_Toolpath
BATCH PROCESS
DIALOGS MESSAGE ON
EDIT PREFERENCE AUTOSAVE YES
What I use is rather simple but works for me. Invalidate macro.
Yes
Then I just run my collision check macro. Collision checking macro will calculate all un-calculated toolpaths then collision check.
DIALOGS MESSAGE OFF
FOREACH tp IN folder('Toolpath\ACTIVATED FOLDER') {
IF NOT tp.Computed {
ACTIVATE TOOLPATH $tp.Name
EDIT TOOLPATH $tp.Name CALCULATE
FOREACH tp IN folder('Toolpath\SELECTED FOLDER') {
IF NOT (tp.Verification.CollisionChecked AND tp.Verification.GougeChecked) {
EDIT COLLISION SHANK_CLEARANCE "0.0005"
EDIT COLLISION HOLDER_CLEARANCE "0.03"
EDIT COLLISION DEPTH Y
DIALOGS MESSAGE ON
I am missing something fundamental here. I created two .mac files but both of them give me an error of variable missing.
I am sure it is something very basic, but I have not jumped into macros, so I am kind of at a loss on where to even start.
Any help or direction would be appreciated.
Steve
add the macros so we can check it...
if you are using @LasseFred macros, you have to call the macro from the usermenu or toolpath menu...
Here you go @rui_rita, calculate.mac. just what @LasseFred had posted.
Like I said, I am most likely just missing a fundamental understanding of something in the process.
Steve
are you calling the macro from the menu? only work if called by the menu
if you use my macro you need to go to the folder pmill2 paste the code below in the toolpath.xml
<?xml version="1.0" ?>
<menupage>
<menupage label="name" multiple_selection="allowed">
<button command='macro W:\MACRO path.mac "%s"' label="name?" multiple_selection="allowed" />
</menupage>
</menupage>
@LasseFred, @rui_rita , OK, I just need to start from scratch to learn about how powermill works with macros. I am not clear on the whole process.
Thanks for the info, it gives me a few things to research.
Steve
you can have this in your macro
Function Main {
//some powermill commands
and it will run normaly like any macro.
but you also can have this
Function Main( REAL $myvariable) {
// some powermill commans and the use of the variable $myvariable
and you will called like this macro mymacro.mac 0.2
then the variable in the macro will have the value 0.2
in @LasseFred macro the incoming value is the selected toolpath
in this case, the menu toolpath.xml will call the macro : mymacro.mac %s
macro mymacro.mac 1st_selected_toolpath
macro mymacro.mac 2nd_selected_toolpath
macro mymacro.mac 3rd_selected_toolpath
macro mymacro.mac last_selected_toolpath
I hope this will help you
Here you go.
this is a macro programming guide also locate on the drive where powermill is.
or you can find it in powermill, in the top toolbar, help -> dokumentation -> Macro Programming Guide.
"C:\Program Files\Autodesk\PowerMill 21.0.30\lib\locale\C\DOC\MacroProgrammingGuide.pdf"
and the forum is a good place to ask questions if you have a little macro understanding.
here are some Macros that could help you.
