Macro remove text block
Message 1 of 11
Hi everyone, I have this simple macro to add a certain block of text on all the tool paths of an NC program which in this specific case is a programmed stop.
I would like to know if there is also a way with a macro to remove them all from the nc program.
Replies (10)
Message 2 of 11
lee_sanders
Hi @Anonymous
This seemed to work for me
STRING Remove = INPUT ENTITY NCPROGRAM "Seleziona NcProgram"
ACTIVATE NCPROGRAM $Remove
EDIT NCPROGRAM $Remove REMOVE ITEM 1
EDIT NCPROGRAM $Remove REMOVE ITEM 2
Lee Sanders
Technical Consultant
Message 3 of 11
Hi, it doesn't work clear the text block but also the toolpath.
I was interested in erasing only the blocks of text.
Message 4 of 11
lee_sanders
Hi @Anonymous
Can you share an example PM project?
Lee Sanders
Message 5 of 11
Yes
Message 6 of 11
lee_sanders
hi @Anonymous
here is a workaround, this relies on the programs and text block being added sequentially.
I'm trying to get a more robust method
// count stores the number of programs in the NC program
INT count = 0
// counter is based on there being a text block before and after each program
INT counter = 0
STRING nc_program = INPUT ENTITY NCPROGRAM "Seleziona NcProgram"
// enter the number of programs in the NC program
string prompt = "Enter number of programs in NC"
$count = input $prompt
$count = $count *2
WHILE $counter < $count {
EDIT NCPROGRAM $nc_program REMOVE ITEM $counter
$counter = $counter + 2
// deletes last text block
Lee Sanders
Message 7 of 11
Hi, I tried your macro, also delete the nc programs together with the blocks of text.
Message 8 of 11
lee_sanders
hi @Anonymous
please try this below, this will remove ALL text blocks from the NC programs
FOREACH $item in components(entity('ncprogram','')) {
if ($item.roottype=='nctextblock') {
EDIT TEXTBLOCK $item.Identifier REMFROMNCPROG
Lee Sanders
Message 9 of 11
Thanks, mythical works fine
Message 10 of 11
ksrinivas94GLE
Observer
Observer
can you please share any video clip ,this macro is not working to us.
Message 11 of 11
ksrinivas94GLE
Observer
Observer
CAN YOU SHARE THE PROCEDURE
