macro help
macro help
kl1445
Message 1 of 18
macro help
kl1445
hi all
I have two Macros, one is D4 and the other is D6. I want to use Macro to determine the model height to execute D4 or D6, but I don't know how to write it. Can anyone help me? Thank you
Replies (17)
Message 2 of 18
icse
you could do somehting like this:
real $sz = limits(folder('Model')[0])[5] - limits(folder('Model')[0])[4]
if $sz >= 30 {
	macro 'c:\pathtoyourmacro\D6-0Angle-RF.mac'
} else {
	macro 'c:\pathtoyourmacro\D4-0Angle-RF.mac'
Message 3 of 18
kl1445
hi icse
I think I did something wrong? Because when executing the following macro, POWERMILL has no action but only counts Z. My powermill version is 2014.
Message 4 of 18
icse
it looks like your formatation is off.
Does any error shows in command line?
Message 5 of 18
kl1445
Unfortunately, PowerMill did not show any errors, so I could not figure out what the problem was.
Message 6 of 18
kl1445
I found the error but I don't know if it's the problem
"No { follows expression"
Message 7 of 18
icse
Your format is off, it looks like you have everything in one line. This does not work.
you need to make the inside of your file looks like this:
if $sz >= 30 {
} else {
NOT like this:
if $sz >= 30 {macro 'c:\pathtoyourmacro\D6-0Angle-RF.mac'}
else {macro 'c:\pathtoyourmacro\D4-0Angle-RF.mac'}
Message 8 of 18
kl1445
You are right. After I re-edited it, powermill can be executed. Thank you very much.
Message 9 of 18
kl1445
hi icse
I would like to ask you another question. If you want to automatically execute D10-10-0-angle or D10-10-1-angle after determining that the angle is 0 or above 0, how do you edit the macro?
Message 10 of 18
icse
This is much more komplex...
Message 11 of 18
kl1445
Got it, thanks for your reply, have a nice day
Message 12 of 18
kl1445
hi icse
I tried to change the macro, but encountered trouble. Now I want to automatically determine the three dimensions of Z <=28, >=48, >=28.01 or <=47.99. However, when executing this macro, the macro executes the two macros D6R0.2 and D8R0.5, which gives me a headache.How do you think such a macro should be edited? Can you help me?
if $sz <= 28 {
macro 'C:\dcam\pmill4\D6R0.2-poin.mac'
if $sz >= 45 {
macro 'C:\dcam\pmill4\D10R0.5-poin.mac'
} else {
macro 'C:\dcam\pmill4\D8R0.5-poin.mac'
Message 13 of 18
icse
if $sz <= 28 {
} elseif $sz >= 45 {
} else {
Message 14 of 18
kl1445
Great, it's no problem now, thank you very much
Message 15 of 18
kl1445
hi icse
Is it possible to use the surface color to determine which macro to execute? For example, in 3D, if there is red, execute macro A, if there is yellow, execute macro B, if there is blue, execute macro C, and if there is both yellow and red, execute macro D?
Message 16 of 18
kl1445
This is the macro I found, but it is used in the hole. I tried to change it, but failed because my English is not good.
FORM RIBBON BACKSTAGE CLOSE RESET ALL VIEW MODEL ; SHADE RAINBOW EDIT MODEL ALL DESELECT ALL EDIT SELECTION MODEL CLEAR EDIT SELECTION MODEL APPLY EDIT SELECTION MODEL FILTER "255,255,0" INT $OP1_HOLES = 0 FOREACH m in folder('model') { $OP1_HOLES = $OP1_HOLES + number_selected(m.Components) } IF $OP1_HOLES > 0 { EDIT SELECTION SMART NO FORM MODELSELECT EDIT SELECTION MODEL DELETE EDIT SELECTION MODEL FILTER " 255,255,0" EDIT SELECTION MODEL APPLY FORM CANCEL MODELSELECT EDIT FEATURECREATE TYPE HOLE EDIT FEATURECREATE CIRCULAR ON EDIT FEATURECREATE FILTER HOLES EDIT FEATURECREATE TOPDEFINE ABSOLUTE EDIT FEATURECREATE BOTTOMDEFINE ABSOLUTE FORM CANCEL FEATURE FORM CREATEHOLE EDIT FEATURECREATE HOLES FIXED ON EDIT FEATURECREATE HOLES DIRECTION DOWN EDIT FEATURECREATE CREATEHOLES FORM CANCEL CREATEHOLE EDIT MODEL ALL DESELECT ALL RENAME Featureset ; "OP1_HOLES" } IF $OP1_HOLES == 0 { MACRO ABORT } REAL $DIA = 0 REAL $DEPTH = 0 // Print out the diameter of each hole FOREACH f in components(entity('featureset','OP1_HOLES')) { IF f.Type == "hole" { PRINT = f.name + " has a diameter of " + f.Diameter $DIA = ROUND(f.diameter,4) $DEPTH = ROUND(f.depth,4) //COUNTERBORE SECTION IF $DIA LE 1.001 AND $DIA GE .999 AND $DEPTH <= .751 { FOREACH ent IN folder('setup') { FOREACH TP IN components(ent) { IF $tp.name == '750_DRILL_1' { /// need some code to skip over this section and contiune on } } } MACRO"C:\(..path..)\1_000x750_cbore.mac" } IF $DIA LE .876 AND $DIA GE .874 AND $DEPTH <= .626 { FOREACH ent IN folder('setup') { FOREACH TP IN components(ent) { IF $tp.name == '625_DRILL_1' { /// need some code to skip over this section and contiune on } } } MACRO"C:\(..path..)\875x625_cbore.mac" } //BLIND TAP SECTION// IF $DIA LE .657 AND $DIA GE .655 { FOREACH ent IN folder('setup') { FOREACH TP IN components(ent) { IF $tp.name == '656_TAP_DRILL_1' { /// need some code to skip over this section and contiune on } } } MACRO"C:\(..path..)\750-10.mac" } IF $DIA LE .532 AND $DIA GE .530 { FOREACH ent IN folder('setup') { FOREACH TP IN components(ent) { IF $tp.name == '546_TAP_DRILL_1' { /// need some code to skip over this section and contiune on } } } MACRO"C:\(..path..)\625-11.mac" } } }
Message 17 of 18
CxyAce丶
Is this only applicable to one?
Message 18 of 18
kl1445
hi CxyAce
This is similar to a macro, but it does more than just determine the color.
