PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Macro help need
2 REPLIES 2
hrh46
210 Views, 2 Replies
Macro help need
I have different hole feature set folders (based on workplane), each have several hole feature (based on diameter).
Anybody can help me for a macro, exporting holes positions in excel file?
List should contain workplane ,hole size (dia), hole depth.
Asking for workplane and hole size is preferred.
Thanks in advance.
2 REPLIES 2
icse
in reply to: hrh46
you need something like this:
if length(project_pathname(0)) == 0 {
      bool $save = 0
      $save = query 'Save Project?'
      if $save {
            project save
      } else {
            return
entity list $featuresets = input entity multiple featureset 'Select FeatureSet for export'
string list $op = {$project_pathname(0)}
int $i = add_last($op, 'Workplane,X,Y,Z,Diameter,Depth')
foreach $fs in $featuresets {
      ACTIVATE WORKPLANE FROMENTITY FEATURESET ${fs.Name}
      string $wpName = replace(entity('workplane','').Name,',','.')
      foreach $f in components($fs) {     
            $i = add_last($op, $wpName + ',' + replace(round($f.WPPoint[0],5),',','.') + ',' + replace(round($f.WPPoint[1],5),',','.') + ',' + replace(round($f.WPPoint[2],5),',','.') + ',' + replace(round($f.Diameter,5),',','.') + ',' + replace(round($f.Depth,5),',','.'))
//the file name you may need to change the / for a \
//this will save the positions into you powermill project
string $file = project_pathname(0) + '/HolePositions.csv'
if file_exists($file) {
      bool $query = 0
      $query = query 'overriede existing file?'
      if $query {
            delete File $file
      } else {
            int $count = 1
            while file_exists($file) {
                  $file = project_pathname(0) + '/HolePositions_' + $count + '.csv'
                  $count = $count + 1
dialogs message off
file open $file for write as output
string $errorstate = powermill.status.errorstate
if $errorstate == 'error' {
      dialogs message on
      string $msg = 'cant write to file: ' + CRLF + CRLF + $file
      message info $msg
} else {
      file write $op to output
      file close output
      ole fileaction 'open' ${file}
I can't test this in powermill atm but this sould give you at least a good starting point.
hrh46
in reply to: icse
Thanks. Very good and professionally.
