Macro Help - Foreach segment in a pattern
jake.montgomery
Message 1 of 10
jake.montgomery
Does anyone know how to achieve a foreach loop for segments within a pattern? I am trying to analyze each segment inside one of my patterns and remove the segment if it doesn't meet my criteria.
Thank you all in advance for any assistance
Replies (9)
Message 2 of 10
kukelyk
Message 3 of 10
jake.montgomery
Thank you very much! That will work perfectly
Message 4 of 10
robert.reedHH7Q9
Is there an updated version of this link? I'm trying to do a similar task and believe this might help me out.
Message 5 of 10
kukelyk
I do not remember what was under the link, but please write what is Your goal.
Message 6 of 10
cfastNJWK6
This isn't exactly what you were asking for, but here is a macro that I wrote for someone wanting to analyze a pattern to find the smallest rad.  You may be able to take some of the logic here and re-purpose it:
ENTITY $pat = INPUT ENTITY PATTERN "Select the Pattern to Analyze"
DIALOGS MESSAGE OFF
EDIT PATTERN $pat.Name SELECT ALL
EDIT PATTERN $pat.Name SPLIT
INT $Segments = segments($pat)
INT $counter = 0
REAL $rad = 0
EDIT PATTERN $pat.Name CURVEEDITOR START
REAL $SmallestArc = 9999999
WHILE $counter < $Segments {
	EDIT PATTERN $pat.Name DESELECT ALL
	CURVEEDITOR MODE DEFAULT CURVEEDITOR SELECT SINGLE_SEGMENT $counter CURVEEDITOR ARC_EDIT MODIFY
	REAL $arc = 0
	$arc = $widget("CEArcEditor.Dimension").value
	IF $arc != 0 AND $arc < $SmallestArc {
		$SmallestArc = $arc
	$counter = $counter +1
CURVEEDITOR FINISH ACCEPT
EDIT PATTERN $pat.Name MERGE
DIALOGS MESSAGE ON
STRING $msg = "Smallest radius = " + $SmallestArc
MESSAGE INFO $msg
Message 7 of 10
robert.reedHH7Q9
I was trying to get the longest line in a pattern. I was able to piece something together to accomplish that. You post some very impressive code though, so I would still be interested if you have something for that purpose.
Message 8 of 10
kukelyk
May the newer Pmills have easier way, but try this one:
EDIT PATTERN ; DESELECT ALL
EDIT BLOCK LIMITTYPE PATTERN
EDIT BLOCK RESETLIMIT "10"
EDIT BLOCK RESET
CREATE TOOL ; BALLNOSED
COMMIT PATTERN ;
ENTITY tp = ENTITY('toolpath','')
INT i = 0
REAL LIST segLenLst = {}
DO {
	INT k = add_last($segLenLst, segment_get_length( $tp, $i))
	$i = $i + 1
} WHILE $i < toolpath_component_count($tp, 'segments' )
DELETE TOOLPATH ;
DELETE TOOL ;
REAL lim = MAX($segLenLst)-0.01
EDIT PATTERN ; SELECT LENGTH LT $lim
EDIT PATTERN ; SELECT INVERT
MESSAGE INFO STRING(MAX($segLenLst))
Message 9 of 10
robert.reedHH7Q9
I'll give that one a shot. This is what I ended up with.
CREATE PATTERN ;
RENAME PATTERN # "PROFILE_BOUNDARY"
EDIT PATTERN "PROFILE_BOUNDARY" INSERT BOUNDARY ;
DEACTIVATE Boundary
REAL $ProfileLength = 0.0
INT $Rows = segments(entity('pattern', ''))
if ($Rows > 1) {
EDIT PATTERN "PROFILE_BOUNDARY" CURVEEDITOR START
CURVEEDITOR MODE REORDER
INT $Row = 0
WHILE $Row < $Rows {
STRING $SegLengthStr = list_cell_value('CEReorderSegments.CEListView',$Row,3)
REAL $SegLength = $SegLengthStr
IF ($Seglength > $ProfileLength) {
$ProfileLength = $Seglength
$Row = ($Row + 1)
$ProfileLength = ($ProfileLength-.01)
EDIT PATTERN "PROFILE_BOUNDARY" SELECT LENGTH LT
$ProfileLength
DELETE PATTERN "PROFILE_BOUNDARY" SELECTED
Message 10 of 10
robert.reedHH7Q9
Actually, I needed that one too. I just figured that would be harder to find. Thank you a whole lot man. It works perfect.
