Macro help. entity list if is_empty
LasseFred
Message 1 of 10
LasseFred
Hello.
I simply got into a problem.
I can't exactly figure out how to do this.
I want to check if my list: Selected_ncprogram is empty if it is select all NCPrograms.
I came up with this:
		ENTITY LIST Selected_ncprogram=explorer_selected_entities()
		IF is_empty(Selected_ncprogram) {
			ENTITY List Selected_ncprogram = folder('NCProgram')
		STRING LIST tools = {}
		FOREACH $nc IN $Selected_ncprogram {
thanks in advance...
______________________
Lasse F.
Replies (9)
Message 2 of 10
LasseFred
Ups sorry..
The problem is my variable "Selected_ncprogram" is empty after my bracket.
Lasse F.
Message 3 of 10
TK.421
you have to populate your list after you create it:
STRING LIST selected_ncprogram = {}
FOREACH ncp IN explorer_selected_entities() {
   INT $i = add_last(selected_ncprogram, ncp.name)
Now you can go through your list:
FOREACH ncp IN selected_ncprogram {
   do whatever
the numbers never lie
Message 4 of 10
TK.421
if you simply want to check if your list is empty you can get the size:
INT i = size(selected_program)
Message 5 of 10
LasseFred
thanks for the answer. i am looking for something else.
if i "explore select" some nc programs the macro works fine.
But if i dont have some nc programs selected, then list all my nc programs.
with this macro code:
But after that curly brackets } there is end of my IF is_empty. the macro "delete all my listed things in my list Selected_ncprogram"
all the code.
Lasse F.
Message 6 of 10
TK.421
sorry, i misunderstood.
try this:
INT i = size(Selected_ncprogram) IF $i == 0 { ENTITY List Selected_ncprogram = folder('NCProgram') }
Message 7 of 10
LasseFred
Sorry it doesn't work.
it throws away all the listed variables when it does the last curly bracket }
	IF $i == 0 {
			// it listed all the nc programs
			// throws all the listed variables away
Lasse F.
Message 8 of 10
Read the "Scope of variables" in PowerMill help
	IF $i == 0 {
		//	ENTITY List Selected_ncprogram = folder('NCProgram')
		$Selected_ncprogram = folder('NCProgram')
Message 9 of 10
TK.421
sorry, I should've paid closer attention. I'm glad you've got an answer. My code should've been something like this:
IF $i == 0 {
  $selected_program = folder(ncprogram)
since the variable is already defined outside the loop. i think by re-initializng it inside the loop, it does not carry through once the loop ends.  Glad you got there!
Message 10 of 10
LasseFred
Thanks to your both.
i have forgot all about re-initializing in {curly-brackets}.
it's been some time since i last worked with macro.
but when you get started again. it's like riding a bike 😉
Lasse F.
