Macro for saving boundary to temp folder
Message 1 of 20
Hi guys,
I would really appreciate if you could help with me the following macro question:
How can i save whats in boundary folder such as supportpins type *pic into an external temp folder with the same type *pic
Replies (19)
Message 2 of 20
rafael.sansao
STRING $TEMP_FOLDER = "C:\Temp" //Change this
FOREACH $Boun IN FOLDER('BOUNDARY') {
	STRING $FILE_SAVE = $TEMP_FOLDER + "\" + $Boun.Name + ".pic"
	KEEP BOUNDARY $Boun.Name $FILE_SAVE YES
Rafael Sansão
OptiNC - www.optinc.tech
Message 3 of 20
rafael.sansao
With some additional checks ...
	IF $Boun.Computed == true AND segments($Boun) > 0 {
Rafael Sansão
Message 4 of 20
Thank you Rafael. I deeply appreciate it, but when I run the macro Powermill gives me an error saying, "Unsupported Powermill command and Feature: STRING
Message 5 of 20
rafael.sansao
Save the attached macro and run it. If the Powermill returns an error, take a print and send it here.
Rafael Sansão
Message 6 of 20
I am currently using PowerMill 2010 and this is the error I'm getting below:
Message 7 of 20
This is the error given by PowerMill.
Message 8 of 20
rafael.sansao
Most macro commands do not work in version 10.
If you want to take advantage of the macros, you'll need to migrate to a newer Powermill version (2016 or later)
Rafael Sansão
Message 9 of 20
Oh, okay, I had a feeling it might be due to my version of PowerMill 2010. Thank you again so much for your help. I deeply appreciate it.
Message 10 of 20
@Anonymous
Have you tried removing the "$" from the line:
STRING $TEMP_FOLDER = "C:\temp"
Generally, when you first declare (create) a STRING VARIABLE....you don't need the $ in front of the name of the variable.
In this case, the variable is called: TEMP_FOLDER
However, anytime after this initial variable declaration, when you need to use or modify the variable's content...you must have the "$" in front of it's name.
Anyway, worth a try...but as @rafael.sansao mentioned...perhaps it's just not possible in Pmill 2010
Good luck,
Glen
Message 11 of 20
lloyd.patton
Try removing the trailing //comment
Message 12 of 20
Yes I tried it without the $ and it gave me the same error.
Message 13 of 20
Also I removed the //comment and it still gave me the same error. However, this code below works for Supportpin_0_1 boundary but then gives me the same error. I need it to run for all the supportpin boundaries.  How can I run the macro once so it goes thru each of the boundaries and saves it in the temp folder?
EXPLORER SELECT Boundary 'SUPPORTPIN_0_1' NEW
KEEP BOUNDARY 'SUPPORTPIN_0_1' FILESAVE
c:\TEMP\SUPPORTPIN_0_1.PIC
EXPLORER SELECT Boundary 'SUPPORTPIN_0_2' NEW
KEEP BOUNDARY 'SUPPORTPIN_0_2' FILESAVE
c:\TEMP\SUPPORTPIN_0_2.PIC
EXPLORER SELECT Boundary 'SUPPORTPIN_0_3' NEW
KEEP BOUNDARY 'SUPPORTPIN_0_3' FILESAVE
c:\TEMP\SUPPORTPIN_0_3.PIC
Message 14 of 20
rafael.sansao
That's not possible. The logic programming language was inserted into the Powermill in the 2012 R2 version.
Rafael Sansão
Message 15 of 20
Referring to Powermill 2010 question: I guess I have to sign up with Scribd to access the entire guideline.
Message 16 of 20
I know there is a way of saving the boundaries in PowerMill 2010 because there are other macros that I run that function perfectly.
Message 17 of 20
I know this code below works for saving supportpin into the temp folder, but for some reason it doesn't overwrite the old supportpin.pic files. How can I delete the old SUPPORTPIN.PIC files, so the new SUPPORTPIN.PIC files saves into the temp folder.
EXPLORER SELECT Boundary "Boundary\SUPPORTPIN_0_1" NEW
ACTIVATE Boundary "SUPPORTPIN_0_1"
KEEP Boundary "SUPPORTPIN_0_1" FILESAVE
"C:\temp\SUPPORTPIN_0_1.PIC"
EXPLORER SELECT Boundary "Boundary\SUPPORTPIN_0_2" NEW
ACTIVATE Boundary "SUPPORTPIN_0_2"
KEEP Boundary "SUPPORTPIN_0_2" FILESAVE
"C:\temp\SUPPORTPIN_0_2.PIC"                    //and so on for the rest of supportpin 3, 4, 5 ,6...
Message 18 of 20
urizenYHS3W
You don't need the EXPLORER SELECT commands, you don't need the FILESAVE, and you don't need to activate the boundary each time. You specify YES to the potential OVERWRITE query.
KEEP Boundary "SUPPORTPIN_0_1" "C:\temp\SUPPORTPIN_0_1.PIC" YES
KEEP Boundary "SUPPORTPIN_0_2" "C:\temp\SUPPORTPIN_0_2.PIC"  YES
 You can delete files and directories with
DELETE FILE <filepath>
DELETE DIRECTORY <dirpath>
Message 19 of 20
Thank you so much. It worked.
Message 20 of 20
Hi guys,
I wanted to know is there a way I can delete curves within a boundary and then save that boundary to an external temp folder using PowerMill?
