Hello PowerUser
I have a macro that I found on the old delcam forum. The macro isolate the diameter and create a new feature set with the diameter
But I want to isolate the depth of EACH feature set.
To have something like:
Ø0.250 X 1.000
Ø0.250 X 2.000
Ø0.250 X 3.000
Ø0.312 X 1.000
Ø0.312 X 2.000
Here's the original who separate the diameter
Real $FDia = 0.0
Real $FDiaOld = 0.0
String $maxItemsA = ""
String $maxItemsB = ""
String $Prefix = ""
String $CurrName = ""
String $NewName = ""
//String $FeatName = ""
//$FeatName = project_pathname (1)
BOOL $err = 1
INT $Counter = 0
EXPLORER SELECT Featureset "Featureset\$FeatureSetName" NEW
RENAME Featureset 1 "MICHEL"
DO {
$FDia = 0.0
//Choisir l'entitée
If $Counter == "4" {
Print "Break here..."
ACTIVATE Featureset "MICHEL"
$maxItemsA = entity('featureset','MICHEL').num_items
//Print Featureset "Featureset\MICHEL.num_items
//$maxItemsA = entity('featureset','MICHEL').num_items
//Print $message
FORM FEATURESELECT
EDIT SELECTION DELETE
EDIT SELECTION TYPE DIAMETER
//DIALOGS MESSAGE OFF
//DIALOGS ERROR OFF
EDIT SELECTION STORE '$Counter' NEW
//EDIT SELECTION STORE '1' NEW
EDIT SELECTION ADD EDIT SELECTION APPLY
FEATURESELECT CANCEL
//Maintenant on copie les trous selectionnés à un nouveau FeatureSet
COPY FEATURESET "MICHEL" SELECTED
ACTIVATE Featureset "MICHEL_1"
// Trouver le nombre d'items dans "MICHEL_1"
// Si le nombre est le même que dans "MICHEL" le programme arrête
$maxItemsB = entity('featureset','MICHEL_1').num_items
IF $maxItemsA == $maxItemsB {
$err = 0
} ELSE {
// Store/Print le diamètre de chaque trou
// Créé une liste vide des REAL
REAL LIST Diams = {}
FOREACH f_dia in components(entity('featureset','MICHEL_1')) {
// Ajoute le diamètre à la liste
$FDia = f_dia.diameter
String s = add_last(Diams, f_dia.diameter)
DIALOGS MESSAGE ON
DIALOGS ERROR ON
//Crée une liste qui va retenir tous les noms des diamètre utilisés Jusqu'ici
//REAL LIST DiamsTotal = {}
//String s = add_last(DiamsTotal, $FDia)
$NewName = $Prefix + "Holes-Dia_" + $FDia +"mm"
// Vérifier si le nom du featureset existe déjà
FOREACH fset IN folder('featureset') {
$CurrName = $fset.name
IF $NewName == $CurrName {
String $prompt = "The name " + $NewName + " Existe déjà! Vous devez rajouter un préfix"
MESSAGE ERROR $prompt
$Prefix = INPUT "Entrer un préfix"
$NewName = $Prefix + "Ø" + $FDia +" arrière"
IF $FDia != "0.0" {
RENAME Featureset "MICHEL_1" $NewName
$Counter = $Counter + 1
} WHILE $err
$FDiaOld = $FDia
//Ramener l'entité à son nom original
DIALOGS MESSAGE OFF
DIALOGS ERROR OFF
EXPLORER SELECT Featureset "Featureset\MICHEL" NEW
RENAME Featureset "MICHEL" $FeatureSetName
DELETE Featureset "MICHEL_1"
DIALOGS MESSAGE ON
DIALOGS ERROR ON
Return
Tank you
