Macro command to open html file using Microsoft Word
iamcdn79
Mentor Mentor
Message 1 of 42
iamcdn79
I just posted this 2 mins ago and it got deleted by someone in the forum page, so sorry if its not as detailed cause I am furious right now about it getting deleted
I am trying to create a macro that opens HTML files using Microsoft Word but get an error saying no program appears to be associated...
Does anyone know the right command to open HTML files?
FUNCTION Main (STRING $Selected_NCProgram)
    // Execute preliminary commands
    KEEP SETUPSHEETS NCPROGRAM SELECTED
    TEXTINFO ACCEPT
    SPLITTER TABEXPLORE
    // Get the main project directory and construct the correct path
    STRING mainDirectory = dirname(project_pathname(0), "/")
    STRING projectSubfolder = project.Name + ""
    STRING htmlFilePath = mainDirectory + "/" + projectSubfolder + "/SetupSheets_files/project_sheets/lineup sheet.html"
    // Attempt to open the specified .html file in the correct directory
    OLE FILEACTION 'open' $htmlFilePath
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Replies (41)
Message 2 of 42
rafael.sansao
On Windows, right-click on the HTML file > Open with > Choose another app > Select Word > Always
This will set Word as the default application for opening HTML files on your computer, and thus, the macro should work correctly.
Rafael Sansão
OptiNC - www.optinc.tech
Message 3 of 42
iamcdn79
It's already set to Word
Windows 11 Pro
Message 4 of 42
rafael.sansao
Something went wrong. When Word is set as the default program for opening HTML, the HTML file icon changes to the Word icon.
When you double-click on the HTML file, the file has to be opened with Word...
Restart your computer and try again...
You can also change the default program through Control Panel > Default Programs
Rafael Sansão
Message 5 of 42
iamcdn79
I think the directory code is incorrect. The macro code is looking into 'C:/Powermill/1792/1792 cavity/SetupSheets_files/project_sheets/lineup sheet.html' directory which doesn't exist for the lineup sheet.html file
The correct directory should be 'C:/Powermill/1792/1792 cavity/SetupSheets_files/project_sheets' to open the file called lineup sheet.html
When I change it to this code it opens a new file explorer window of that directory showing the lineup sheet.html file but doesn't open that file
    TEXTINFO ACCEPT
    SPLITTER TABEXPLORE
    // Get the main project directory and construct the exact path
    STRING htmlFilePath = mainDirectory + "/" + projectSubfolder + "/SetupSheets_files/project_sheets"
    // Open the specified .html file if it exists
Windows 11 Pro
Message 6 of 42
rafael.sansao
Try this:
    TEXTINFO ACCEPT
    SPLITTER TABEXPLORE
    STRING $mainDirectory = REPLACE(project_pathname(0), "/", "\")
    STRING $htmlFilePath = $mainDirectory + "\SetupSheets_files\project_sheets\lineup sheet.html"
Rafael Sansão
Message 7 of 42
iamcdn79
Same error as before because I think its looking in the wrong dir.
The correct dir should be 'C:\Powermill\1792\1792 cavity\SetupSheets_files\project_sheets' but the error code is showing dir called 'C:\Powermill\1792\1792
cavity\SetupSheets_files\project_sheets\lineup sheet.html' which doesn't exist
This is the dir it should be pointing too for the file called lineup sheet.html
Windows 11 Pro
Message 8 of 42
nguyenthinhvt95
Hi @iamcdn79 ,
I tested your macro and it's working well when opening an HTML file by Excel.
in my opinion, the macro is OK, the problem is Word not suitable to open HTML.
Message 9 of 42
iamcdn79
If you change it to Word instead of Excel to open HTML does it still work?
Windows 11 Pro
Message 10 of 42
iamcdn79
My macro doesn't even work for Excel files when I change the extension to .xlsx and Excel is already the default pgm for that extension.
Windows 11 Pro
Message 11 of 42
rafael.sansao
Try this:
    TEXTINFO ACCEPT
    SPLITTER TABEXPLORE
    IF NOT file_exists($htmlFilePath) {
		MESSAGE WARN "File not exists"
		MACRO ABORT
	} ELSE {
		STRING $cmd_content = "@echo off" + CRLF + 'start "" "' + $htmlFilePath + '"'
		STRING $cmd_path = $mainDirectory + "\run.cmd"
		FILE OPEN $cmd_path FOR WRITE AS cmd
		FILE WRITE $cmd_content TO cmd
		FILE CLOSE cmd
		OLE FILEACTION 'open' $cmd_path
		WAIT 1
		FILE DELETE $cmd_path
Rafael Sansão
Message 12 of 42
iamcdn79
Yes! that opens, but i get an error on line
FILE DELETE $cmd_path​
after the file opens.
Is it trying to delete the lineup sheet.html file or that directory that it exists?
Removing that line seems to run without issues.
Windows 11 Pro
Message 13 of 42
rafael.sansao
    TEXTINFO ACCEPT
    SPLITTER TABEXPLORE
		MACRO ABORT
	} ELSE {
		FILE CLOSE cmd
		WAIT 1
		DELETE FILE $cmd_path
Rafael Sansão
Message 14 of 42
iamcdn79
Here is the complete code
    IF ($powermill.Status.MultipleSelection.First) OR ($powermill.Status.MultipleSelection.Total == 0) {
    TEXTINFO ACCEPT
    SPLITTER TABEXPLORE
		MACRO ABORT
	} ELSE {
		FILE CLOSE cmd
         //Check if it is the last selection or if there are no items selected
        IF ($powermill.Status.MultipleSelection.Last) OR ($powermill.Status.MultipleSelection.Total == 0) {
            WAIT 1
is there a way to close the microsoft word lineup sheet.html file if it is already one when running this code?
Windows 11 Pro
Message 15 of 42
rafael.sansao
You can try using Powershell to close the file, but you will need to select Powershell as the default program for executing ps1 files.
This will only work if your computer's group policy allows scripts to be executed.
		IF file_exists($htmlFilePath) {
			STRING $char = "$"
			STRING $ps1_content = $char + 'path = "' + $htmlFilePath + '"'
			$ps1_content = $ps1_content + CRLF + $char + 'word = [Runtime.InteropServices.Marshal]::GetActiveObject("Word.Application")'
			$ps1_content = $ps1_content + CRLF + 'foreach (' + $char + 'doc in ' + $char + 'word.Documents) {'
			$ps1_content = $ps1_content + CRLF + '    if (' + $char + 'doc.FullName -eq ' + $char + 'path) {'
			$ps1_content = $ps1_content + CRLF + '        ' + $char + 'doc.Close()'
			$ps1_content = $ps1_content + CRLF + '        break'
			$ps1_content = $ps1_content + CRLF + '    }'
			$ps1_content = $ps1_content + CRLF + '}'
			STRING $ps1_path = $mainDirectory + "\run.ps1"
			FILE OPEN $ps1_path FOR WRITE AS cmd
			FILE WRITE $ps1_content TO cmd
			FILE CLOSE cmd
            OLE FILEACTION 'open' $ps1_path
            WAIT 2
            DELETE FILE $ps1_path
		TEXTINFO ACCEPT
		SPLITTER TABEXPLORE
		MACRO ABORT
	} ELSE {
		FILE CLOSE cmd
            WAIT 1
Rafael Sansão
Message 16 of 42
iamcdn79
So I did all that and I don't get any errors but it doesan't close the word file linup sheet.html when it is open.
I think it could because when I always close it manually its asking me if it needs to be saved or not due to a macro I have which runs and changes values automatically everytime it opens that particular file.
Is there a way to add a no to not to save the file then close it?
Windows 11 Pro
Message 17 of 42
rafael.sansao
Replace:
By:
$ps1_content = $ps1_content + CRLF + '        ' + $char + 'doc.Close(0)'
Rafael Sansão
Message 18 of 42
iamcdn79
No change
Windows 11 Pro
Message 19 of 42
rafael.sansao
			STRING $char = "$"
			FILE CLOSE cmd
			STRING $cmd_content = "@echo off" + CRLF + 'powershell -ExecutionPolicy Bypass -File "' + $ps1_path + '"'
			FILE CLOSE cmd
			WAIT 2
		TEXTINFO ACCEPT
		SPLITTER TABEXPLORE
		MACRO ABORT
	} ELSE {
		FILE CLOSE cmd
            WAIT 1
Rafael Sansão
Message 20 of 42
iamcdn79
No go.
Would a lockfile be preventing it from closing? When I have the file open there is a hidden file in the dir called "~$nep sheet.html"
Windows 11 Pro
