[macro] check if a colour exists in a specify level
moraschini
moraschini
Hello everyone, is possible check with a macro if a colour exists in a specify level?
colour: 181,102,0
level: 170
thanks in advance for the help
icse
Try this:
EDIT SELECTION MODEL TYPE LEVEL
EDIT SELECTION MODEL FILTER "170"
EDIT SELECTION MODEL TYPE COLOUR
EDIT SELECTION MODEL FILTER "181,102,0"
if max(apply(folder('model'), "number_selected('model', this.Name)")) > 0 {
	message info 'Found a surface'
moraschini
hello, if it isn't a furface but a bidimensional line?
icse
yes, this should also find lines.(everything in lvl '170' with your given color '181,102,0')
moraschini
hello @icse, it works well, one question, can you explain me the funcion "max" and "applay" please?
i did't find in the guide.
thanks a lot for your help
icse
Apply:
string apply( list list, string expression )
Returns a new list consisting of the values obtained by applying 'expression' to each element of the input list list. In the expression you can give the keyword this to refer to the current list item
Example: Add "_1" to a list of strings
STRING LIST mlist = {'a', 'b', 'c', 'd'}
STRING LIST ulist = apply(mlist, "this + '_1'")
print ${ulist[0]}
// prints "a_1"
print ${ulist[1]}
// prints "b_1"
Example: To find the minimum Z value of the toolpaths in an NCProgram
PRINT = min(apply(folder('ncprogram'), 'limits(this)[4]'))
max:
real max( list numeric a )
Find the largest value in a list of numbers.
moraschini
thnaks a lot @icse
