Macro: Block Z_MAX
Macro: Block Z_MAX
rafael.sansao
Advisor Advisor
Macro: Block Z_MAX
rafael.sansao
I would like to be checking what is the Z_max of the block (in relation to the workplane of the toolpath). Regardless of the type of block.
Attached is a project with some proposed situations.
Any ideas how to get this value by macro?
Note: I currently export the block, import and read the limits. I'm looking for a more effective method.
Rafael Sansão
OptiNC - www.optinc.tech
iamcdn79
I use this and works for me
REAL Top_Of_Block = Block.Limits.ZMax
// MESSAGE INFO "Top Of Block Is $Top_Of_Block"
MESSAGE INFO "Top Of Block Is ${(round(Block.Limits.ZMax , 3))}"
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
rafael.sansao
Did you open the attached project?
Activate the toolpaths and run your macro. The result is always zero.
Note: In the name of the toolpath it has the value of Z_Max
Rafael Sansão
iamcdn79
Yes I used your attached project, but when I open the block form it has z max as 0 for every toolpath, not sure why it is showing that value for every toolpath. Is that the block after exporting importing?
Windows 11 Pro
rafael.sansao
Problem solved:
REAL ARRAY Lims[] = limits(block)
REAL MaxZ = Lims[5]
MESSAGE INFO $MaxZ
Rafael Sansão
