list level" folders" macro to delete
irishbball
New Member New Member
irishbball
New Member
New Member
i been trying to figure out how to create a macro that deletes a Folder that is listed in the Levels list ( i need to add levels to folders, because of revision changes)
there is no actual option to create a folder, other then from command line
this macro  is what i use:
create folder 'Level' 'FolderName'
ACTIVATE FOLDER "Level\FolderName"
RENAME FOLDER "Level\FolderName"
but now i want to reverse it, and be able to delete a folder in the levels , and be able to use a drop down.
any help with greatly appreciated
rafael.sansao
Try this:
STRING LIST $fLevel = GET_FOLDERS("Level")
INT $sum = 0
FOREACH f IN $fLevel {
	${fLevel[$sum]} = replace($f,"Level\","")
	$sum = $sum + 1
INT $C = INPUT CHOICE $fLevel "Choose the folder"
STRING $folder = "Level\" + $fLevel[$C]
DELETE LEVEL FOLDER $folder
Rafael Sansão
OptiNC - www.optinc.tech
