Link Type in AMPPU
cfastNJWK6
Link Type in AMPPU
cfastNJWK6
@rafael.sansao Since you helped me out with my last hidden parameter I thought I would include you here.
I am trying to force a post to output a G0 move on "Skim Moves" that are programmed at 3000 IPM.  The post processor has a parametr for "Skim Rate" but no parameter for Link Type.
Is there a hidden parameter for link type? Or do I have to find a different way to accomplish this?
evo80
Couldn't you use the parameter Max Rate rather than Skim Rate?
cfastNJWK6
I don't understand how that would solve my issue.  I am able to get the skim rate, I am not able to get the type of link.
I would like my logic to be something like this:
IF %p(Skim Rate)% == 3000 && %p(Link Type)% == "SKIM" THEN
Output a G0 move instead of a G1 move
The problem is that there is no parameter for Link Type
evo80
I see, I guess I was thinking Heidenhain where Max Rate will output FMax
rafael.sansao
%p(Feed Rate Type)%=="SKIM" & %p(Feed Rate)%==3000
Rafael Sansão
OptiNC - www.optinc.tech
cfastNJWK6
Thank you @rafael.sansao , this appears to be doing the trick.
