PowerMill Forum
Welcome to Autodesk’s PowerMill Forums. Share your knowledge, ask questions, and explore popular PowerMill topics.
Keep steep and shallow toolpath off flats?
9 REPLIES 9
Message 1 of 10
johnc4668
673 Views, 9 Replies
I use the steep and shallow toolpath quite a bit but notice it likes to cut flats, Anyway to keep the toolpath off flats? I know you can do it with block but wonder if theres a better way? Thanks fellas!
9 REPLIES 9
Message 2 of 10
craig.shipley
in reply to: johnc4668
You could use the component thickness and set your flat surfaces to "collision" ?
Kind Regards
Message 3 of 10
cfastNJWK6
Or create a boundary around the flat areas and limit the toolpath to stay outside of the boundary?
Message 4 of 10
johnc4668
in reply to: craig.shipley
@craig.shipley heres the part, i want it to stay off all the inner flats but machine down to the floors with out making passes on the flats
Message 5 of 10
craig.shipley
I can never see the images unless they're attached for some reason...
Any chance you can attach please?
Message 6 of 10
johnc4668
Message 7 of 10
craig.shipley
OK so can you set the bottom faces as collision?  If you do, the tool will get as close to the surface as possible without touching it...
Or you could use a coundary as suggested by another user...
I can't think of another way off the top of my head, of course your can just calculate the full toolpath then delete the flat segments afterwards, either my manual selection or using a boundary to EDIT > LIMIT...
Kind Regards
Message 8 of 10
You could also use a Min Z limit and set it just above that surface since it looks like that is the lowest point of the toolpath.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
Message 9 of 10
@Jonathan.Artiss-DSI  i tried that earlier. it works but gets choppy at the floors. Maybe its a tolerance thing, im not sure.
Message 10 of 10
james.probert
Good to see a solution has been accepted. I'll just add that we're currently working on a project that will allow users to automatically exclude flat areas from a steep and shallow toolpath.
James Probert
Software Engineer
