I'm trying to create a macro using INT to always round UP the Z Max to the nearest integer in the block form - for example
ZMax = 34.245mm - use the Macro to round it UP to 35mm
And for this to work in all cases. Has anyone done anything similar?
Thanks!
Solved by rafael.sansao. Go to Solution.
IF INT($Block.Limits.ZMax) < $Block.Limits.ZMax {
EDIT BLOCK ZMAX ${INT($Block.Limits.ZMax) + 1}
Rafael Sansão
