Input and Query positions on screen
Eskondedo
Message 1 of 9
Eskondedo
Hello everyone,
   I am running some very logic and input heavy macros.  In the macro I am using INPUT CHOICE  and QUERY  functions.  It seems that these boxes, while not an overly critical thing, seem to appear wherever the mouse is on the screen.  Is there a way to position these boxes centered on the screen everytime?  Ive scoured the forums and the macro guide but nothing seems to cover where the boxes appear or how to position them.  Any help would be appreciated!
Thanks all.
Replies (8)
Message 2 of 9
iamcdn79
That is currently the intended behavior for macro's such as those and where your cursor lies. Nothing that can be done about it as of right now
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Message 3 of 9
rafael.sansao
Extract the 'Center_Popup' folder to the 'C:\dcam' directory
Add the call macro before your all popups:
MACRO 'C:\dcam\Center_Popup\Run.mac'
REAL X = INPUT "Enter a number"
Rafael Sansão
OptiNC - www.optinc.tech
Message 4 of 9
Eskondedo
Thank you for the hasty response.  This does exactly what I'm looking for but with one hiccup.  We run multiple monitors and if Powermill is on a secondary it always pops up on the primary.  Is there any way to get it to pop up on the monitor where Powermill is shown?
Thanks in advance
Message 5 of 9
rafael.sansao
This version supports multiple monitors.
Rafael Sansão
Message 6 of 9
Eskondedo
Hello again,
    With this latest update to Powermill this capability no longer works.  The center popup is moving the mouse to the center of the screen but not the Powermill Prompt boxes.  Could you lend a hand again?
Message 7 of 9
rafael.sansao
It seems that the Powermill response time has changed. This new version should work.
Rafael Sansão
Message 8 of 9
Eskondedo
Thanks for the quick response,  I downloaded and rerun the program/macro and it still doesn't seem to be snapping the boxes and mouse to the center of the screen.  The tooltip will snap to center but the box appears wherever the mouse is on the screen prior to the tooltip moving.
Message 9 of 9
rafael.sansao
I modified the "Run.mac" macro.
Basically you need to increase the value until it works the way you expect (the response time may vary on each computer):
OLE FILEACTION 'OPEN' 'C:\dcam\Center_Popup\Center_Popup.exe'
INT c = 0
WHILE $c < 10 {
$c = $c + 1
Rafael Sansão
