If we are spiral off option use in finish strategy corner radius stock left
bd.yogesh
bd.yogesh
Hiii, when we are using any finishing strategy using spiral option off, we found stock left in corners, If we are using spiral on option extra material will remove in same. we are using high speed machining and also high-speed tool.
plz let me know how to resolve this issue.
EX:-
If we are using Diameter 6 ballnose cutter for radius up to 3mm there stock left up to 60 to 80 micron
iamcdn79
In your spiral off toolpath you have the fillet corners box turned on for high-speed machining which always adds a radius to internal corners which leaves you more material. Turning it off or putting a value of 0 will produce the same result as spiral in the corners.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
