How to set limits for continuous 5 axis machining
iamcdn79
Mentor Mentor
Message 1 of 22
iamcdn79
This is my first attempt at creating a continuous 5 axis machining toolpath. I need some input into how I can set limits on my C axis so it doesn't hit the table. In the attached video when the C-Axis goes to +180 it will hit the table. How can I make the safe area between C -90 and +90?
I've tried changing the tool axis limits and also creating a polygon window using the update within region option to no avail.
I don't know if this is possible or not.
Intel Core i9 13900KF CPU
128 GB Kingston Beast DDR4 SDRAM
PNY RTX A2000 6GB Video Card
WD 1 TB SSD Hard Drive
Windows 11 Pro
Accepted solutions (3)
Replies (21)
Message 21 of 22
jonathan.artiss
@iamcdn79
@iamcdn79 wrote:
@jonathan.artiss when you changed your azimuth angle to 180 in the machine axis control that required a recalculation of the toolpath.
Is there a way it would work by not having to recalculate the toolpath?
When I access the dynamic machine control and select 'Swap machine tool configuration" and click 'Update Toolpath' it wouldn't require a recalculation for a 3+2 toolpath.
I can click on 'Swap machine tool configuration' but the 'Update Toolpath' icon is grayed out for the toolpath you created.
Since its a full 5 toolpath, you cannot use the DMC to update the configuration. If you don't want to recalculate the toolpath, you can edit within region.
Select the entire toolpath as your "Save selection" > Specify change > click on Tool Axis > Toggle over the the Machine axis control page > enter the second solution "180" to the Azimuth and apply it to the toolpath.
Cheers,
Jonathan Artiss
Application Engineer
Submitting & Viewing Support Requests | Web Support | Phone Support
Message 22 of 22
iamcdn79
Thanks @jonathan.artiss thats a good helpful tip!
Windows 11 Pro
