How to remove a specific Ribbon tab
theis_knudsen
theis_knudsen
Hello.
Is it possible to make a Macro to remove a specific Ribbon tab?
Right now, when i make an update and everyone else want it they have to do manual work.
I made one that imports the new macro, but you have to delete the old one because i can't just say number 2 because everyone has different ribbon setups.
FORM CustomRibbon CustomiseRibbon
EDIT CUSTOMRIBBON SOURCE
EDIT CUSTOMRIBBON IMPORT FILEOPEN
"Path to the file"
MESSAGE INFO "Delete old Genistreger and press OK"
Sean571
Here you go, just replace the variable "tabToFind" with the name of the tab you want removed
//Name of tab to remove
string tabToFind = "New Tab"
// There are 17 default ribbon tabs if you include the quick access toolbar
int numberOfDefaultTabs = 17
string list tabs = ribbon_visible_tabs()
int numOfActualTabs = size(tabs)
int i = $numberOfDefaultTabs
while $i < $numOfActualTabs {
    string widgetName = "Ribbon." + $tabs[$i]
    string tabName = $widget($widgetName).Label
    if lcase($tabName) == lcase($tabToFind) {
        string cmd = "EDIT CUSTOMRIBBON DESTINATION '" + $widgetName + "'"
        docommand $cmd
        $cmd = "EDIT CUSTOMRIBBON REMOVE '" + $widgetName + "'"
        docommand $cmd
        EDIT CUSTOMRIBBON APPLY FORM CANCEL CUSTOMRIBBON
        break
    $i = $i+1
Sean Wroblewski
Applications Engineer
