How to get the NC Program Tool Number output to my setup sheet
rmiller
rmiller
I am trying to modify my existing setup sheet template to show the tool number that’s set in the NC Program verses the toolpath.  I have multiple instances of the same toolpath and I want to use a different tool for each.  My current template uses {tool.number} and it will output the tool number correctly for the first toolpath but doesn’t change for subsequent toolpaths.  I’ve also tried {stoolpath.ToolNumber}{nctoolpath}.ToolNumber and {nctoolpath}.ToolNumber.Value without success .
I’m also having trouble trying to output the fixture offset name.  I’ve tried {stoolpath.FixtureOffset.Name} and {nctoolpath}.FixtureOffset.Name and neither seem to work.
Any help would be appreciated.
Rick
design
try {ToolNo}
Vilchez
rmiller
@design
{ToolNo} gives me the same results as before.  The first toolpath has the correct tool number of 53 but the next two toolpaths should be 63 and 73 but remain 53.
Rick
Vasago
{ncprogram}.nctoolpath[0-n].tool.number
print = entity('ncprogram', '<ncprogram name>').nctoolpath[0].tool.number
rmiller
This doesn't seem to work in my setup sheet template either.
dans4DQYP
This is mine it seems to work for 2018
rmiller
@dans4DQYP
I had tried {nctoolpath}.FixtureOffset.Name  and it didn't work, but {nctoolpath.FixtureOffset.Name} as you showed did. So I changed {nctoolpath}.ToolNumber to {nctoolpath.ToolNumber} and got the tool numbers I was looking for. Placement of those brackets makes all the difference.
Thanks for the help,
Rick
