How to delete remove some toolpaths from group in power mill 2019
malinsAM3TM
malinsAM3TM
Good morning
After making drilling programs we are making groups and adding tool paths to group.
But some times we don't want some programs from that group
But
In power mill 2019 I am not able to delete some tool paths.
In earlier versions it was possible
Is there any way out for this problem.
Thanks and  Regards
Nivrutti Mali
cfastNJWK6
Either right click on the toolpath in the group and click "Remove from Group"
Or highlight the Toolpath in the group and hit "Delete" on your Keyboard.  This will remove the toolpath from the group, but not delete it from the Toolpaths portion of the explorer window.
malinsAM3TM
Hello Sir,
No such option in showing when right clicked on group neither the toolpath gets highlighted.
We are using Power mill 2019.
FYI
Nivrutti
cfastNJWK6
It does appear that you have something strange going on.  Hopefully someone for @Anonymous  will chime in.  In the latest picture that you uploaded, it shows 'Groups' being selected, but the menu shows a toolpath name at the top.  Normally wherever you right click, that entity is selected.  Are you able to select the toolpaths that are in the group?
malinsAM3TM
Hi
I am able to select the toolpath from group I can sort I can on and off
but not able to remove tool path from group.
I am using PM2021, I can remove the tool path from the group, please refer to the image as an attachment. I suppose you should select the tool path then right-click.
