How to add Stepover and Stepdown to PostProcessor?
lxc
lxc
The variables stepover and stepdown could not be found in the Post Processor, and I could not directly post-process the corresponding value of the tool path.
Is there a way to define funtion in script to implement the output of these two variable values?
Or through the macro command and user variables to achieve the output of the two variable values?
boopathi.sivakumar
@lxc
Its a standard parameter you can find it inside the toolpath parameter list or else you can search
Boopathi Sivakumar
Senior Technology Consultant
lxc
Hi.
I have been using the Post Processor Utility for 2017 in order to make post-processing available to more Powermill versions.
Thank you for letting me see that the post processor in 2019 has more comprehensive variables.
