How can I set the FileFormat for curve export to be ASCII
per.soerensen2EV6F
per.soerensen2EV6F
Hi
Can I export Shank and Holder profile in IGES/ASCII
If i import a dgk file in to AMDEU i can set resources to "FileFormat ASCII" and i get a readable file with all curve points.
I can't get this to work when exporting directly from PowerMILL.
Is there a easier way to get the holder and shank profile as a coordinate file ?
Jonathan.Artiss-DSI
Hi @per.soerensen2EV6F
Can you share the need to change the file type?
Maybe also outline your workflow for exporting the tool profile from Powermill.
Jonathan Artiss
Senior Applications Engineer | DSI
Autodesk Expert Elite member
DSI, Design and Software International Autodesk Gold Partner
per.soerensen2EV6F
Hi Jonathan
I use the standard save function on the tool form.
In this case .dxf if I open the file in notepad++ I cant read the information.
I like to get a format that I can use to automatic "build" the tool in a simulation software.
So a text file a bit like a NC code 🙂
per.soerensen2EV6F
For the holder and shank I use this now.
FOREACH $shank_cmp IN $entity('tool',$tl).ShankSetValues {
FILE WRITE ${"L: " + $shank_cmp.Length} TO outputfile
FILE WRITE ${"DU: " + $shank_cmp.UpperDiameter} TO outputfile
FILE WRITE ${"DL: " + $shank_cmp.LowerDiameter} TO outputfile
